[fdo-users] fdo for autocad connection to arcsde 45 character
limitation
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Wed Apr 16 16:40:42 EDT 2008
Hi Jim,
You may want to try the patch dll's provided by OSGEO:
http://fdo.osgeo.org/content/fdo-323-downloads#3.2.3_patches
See Ticket #294
Romy.
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Landwehr, Jim [JLandwehr at waukeshacounty.gov]
Sent: Wednesday, April 16, 2008 4:19 PM
To: 'fdo-users at lists.osgeo.org'
Subject: [fdo-users] fdo for autocad connection to arcsde 45 character limitation
Hello,
We are encountering an exception error when we try and connect to our ESRI SDE database (SQL Server) using AutoCad Map 2008, which I'm told uses the Open source FDO developed here. We have found on the autodesk forums that there evidently is a 45 character limitation on features using a connection. Does anyone know if this is going to be addressed by the arcsde fdo developer? The 45 character issue is NOT an ESRI limitation, and is prohibiting our autodesk users from connecting to our new database.
The autodesk forum thread is found (near the bottom, from bleestein) at;
http://discussion.autodesk.com/thread.jspa?messageID=5699330
Any help or insight appreciated.
Jim
James Landwehr, GISP
LIS Analyst
Waukesha County Parks and Land Use
262-548-7946
jlandwehr at waukeshacounty.gov
http://www.waukeshacounty.gov/landandparks
More information about the fdo-users
