[fdo-users] FDO PostGIS provider status
Tim Bowden tim.bowden at westnet.com.au
Thu Apr 17 12:00:35 EDT 2008
On Thu, 2008-04-17 at 05:56 -0700, Bruno Scott wrote:
> Hi Tim,
> I'm about to summit good patch for PostGIS provider.
> No more problem with write access.
> We have fix a lot of stuff.
> For the performance i have not done any bench yet
> but it seems ok.
Thanks Bruno.  I'll check it out in due course.
Regards,
Tim Bowden
> Bruno
> Tim Bowden wrote:
> > On Sun, 2008-04-13 at 22:33 -0700, Jason Birch wrote:
> >> Hey Tim,  Bruno Scott (GeoMap Groupe) has been working on the PostGIS
> >>  provider.  Hopefully we'll see the code start coming in soon so the
> >>  fixes can be reviewed and rolled into an interim release of the
> >>  provider.  Have you tried the current version of the provider?  It
> >>  works OK in MapGuide as long as you don't run into any of the
> >>  outstanding bugs.  I'd be interested in seeing a performance
> >>  comparison of the two...  Jason  ________________________________
> > No, I haven't tried it yet.  I will be relying on an Autodesk affiliated
> > developer to be able to build an app for one of my clients on a
> > potential project.  It will have postgis as the primary data source.
> > I'm trying to sus out (and cost) what obstacles we will have if we get
> > the go ahead.  Unfortunately I don't have the time to play with it
> > myself.  If we get the go ahead (not at all certain at this point),
> > there may be an opportunity to put some limited dev funds into this if
> > we can be sure it will bear fruit in time.
> > Regards,
> > Tim
> >> From: Tim Bowden
> >> Subject: [fdo-users] FDO PostGIS provider status
> >> What's the status of the FDO PostGIS provider?  Is the best way to go to
> >> use the ogr provider? Any issues with this (performance, read/write
> >> etc)?
> >> _______________________________________________
> >> fdo-users mailing list
> >> fdo-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
