[fdo-users] Help Problem ./UnitTest SDF
Jack Lee
jack.lee at autodesk.com
Fri Apr 18 13:37:05 EDT 2008
Do you downloaded the sdf gzip file?
If that is the case, the gzip file does not contain the unit test data. There is a separate gzip file for the sdf unit test data but it does not seem to be posted.
You can get the sdf unit test data from
http://svn.osgeo.org/fdo/trunk/Providers/SDF/TestData/
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jérémie Formica
Sent: Friday, April 18, 2008 3:29 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Help Problem ./UnitTest SDF
Hello when I execute ./UnitTest In DIrectory /OpenSource_FDO/Providers/SDF
/Src/UnitTest they are many error.
##Failure Location unknown## : Assertion
Test name: 10SelectTest.TestBaseProps
caught unknown exception
Test name: 10SelectTest.TestBothProps
Test name: 10SelectTest.TestAllProps
TestCommonMiscUtil.cpp:50:Assertion
Test name: 10SelectTest.select_aggregates_should_fail
SDFPROVIDER_33_FILE_EXISTS
Test name: 18FdoMultiThreadTest.QueryTest
setUp() failed
Test name: 18FdoMultiThreadTest.InsertQueryTest
setUp() failed
Failures !!!
Run: 110 Failure total: 75 Failures: 75 Errors: 0
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080418/a6c23dce/attachment.html
More information about the fdo-users
