[fdo-users] Problems reading MultiGeometry values from .tab
Jackie C. Ng
jumpinjackie at gmail.com
Sat Aug 9 07:55:36 EDT 2008
I ran your sample data through FDO Toolbox and I get the same empty Geometry
field.
Best to file a ticket on this matter.
- Jackie
Paul Eggleton wrote:
> Hi there,
> I'm having a problem reading MultiGeometry records from a MapInfo .tab
> file using the OGR provider (FDO 3.3.1) from my application written in
> C++ - they are apparently empty (GetCount() returns 0 and GetText()
> returns "GEOMETRYCOLLECTION()"). Using the ogrinfo command line utility
> from GDAL 1.4.2 and 1.4.4 shows valid geometry data for each record in
> the same file, so either I am not calling the right functions or there
> is a bug somewhere in FDO or the 1.4.3 version of GDAL distributed with
> FDO.
> The layer this problem is occurring with along with an abridged source
> file showing how I'm trying to access the file can be found here:
> ftp://ftp2.ggpsystems.co.uk/fdo_tabtest.zip
> Any suggestions or information would be greatly appreciated!
> Thanks,
> Paul
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Problems-reading-MultiGeometry-values-from-.tab-tp18892776p18904220.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
