[fdo-users] Does IApplySchema handle removed classes / removed
properties?
Zac Spitzer
zac.spitzer at gmail.com
Mon Aug 11 01:41:11 EDT 2008
i don't think there currently is one
On Wed, Jul 30, 2008 at 11:59 AM, Jackie C. Ng <jumpinjackie at gmail.com> wrote:
> So I guess the question then becomes what is the FDO way to blow a cached
> schema to smithereens (if any)? :-)
> - Jackie
> zspitzer wrote:
>> It might be the effects of FDO schema caching?
>> In Mapguide I just re-save the featuresource which blows away the cache
>> On Tue, Jul 29, 2008 at 12:08 AM, Jackie C. Ng <jumpinjackie at gmail.com>
>> wrote:
>>> Hi All,
>>> I am having trouble with the IApplySchema command with regards to
>>> removing
>>> classes and/or class properties.
>>> After executing an IApplySchema on a modified schema, the schema shows
>>> all
>>> the signs of the class being removed, same applies for removed
>>> properties.
>>> But if were to execute an IDescribeSchema afterwards, the schema returned
>>> from that command still has the class/property that was supposed to be
>>> removed.
>>> I wrote a test application to verify my findings.
>>> TestDeletePropertyRaw()
>>> http://code.google.com/p/fdotoolbox/source/browse/trunk/TestApp/TestApp.cs#35
>>> TestDeleteClassRaw()
>>> http://code.google.com/p/fdotoolbox/source/browse/trunk/TestApp/TestApp.cs#163
>>> In both methods, the class/property is indicated as removed after the
>>> IApplySchema executes, but then it reappears in the schema returned by
>>> the
>>> subsequent IDescribeSchema command.
>>> Am I doing something wrong here?
>>> - Jackie
>>> http://themapguyde.blogspot.com
>>> http://www.linkedin.com/in/jackieng
>>> View this message in context:
>>> http://www.nabble.com/Does-IApplySchema-handle-removed-classes---removed-properties--tp18689217p18689217.html
>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>> fdo-users mailing list
>>> fdo-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> View this message in context: http://www.nabble.com/Does-IApplySchema-handle-removed-classes---removed-properties--tp18689217p18724819.html
Zac Spitzer -
+61 405 847 168
More information about the fdo-users
