[fdo-users] SDE FDO is making too many connections
Techswami
techswami at hotmail.com
Fri Aug 15 01:56:56 EDT 2008
i am using arcsde 9.2 with MGE 2009 as well as MGOS 2.0
layer = 40
Database : SQL server 2005
here are the observations
1. with SDE 9.2 MGE makes so many connections that they use all the memory
and SDE server crashes
2. i went to esri and did increased the size still MGE is making more
connection for no reason
every zoom create connection to SDE
identify does the same
3. I have connection pooling on so why does it do it
any one found the same issue
apparently is not the case with 9.1 SDE provider it works really well what
in the world change in 9.2 arcsde
dll is causing that much errors.
thanks
Tony
View this message in context: http://www.nabble.com/SDE-FDO-is--making-too-many-connections-tp18994212p18994212.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
