[fdo-users] How does FDO handle invalid fgf geometries?
Jackie Ng jumpinjackie at gmail.com
Thu Aug 21 23:56:31 EDT 2008
I strongly suspected that it was some other error than running out of memory.
Good to know my suspicions are confirmed.
- Jackie
Dan Stoica wrote:
> Did some investigations on this matter. Turns out that:
> a) the polygon in question has a ring which is not closed.
> b) the geometry factory throws an appropriate exception "Open ring"
> c) the exception is not caught by GetText()
> d) for some odd reason the exception is turned into "memory allocation
> error"
> Therefore, the quick solution for Jackie is to catch the exception.
> Going forward, we might want to get rid of the 'is polygon closed?'
> test...
> Dan.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
> Sent: Thursday, August 21, 2008 10:51 AM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] How does FDO handle invalid fgf geometries?
> Jackie Ng wrote:
>> Hi All,
>> How does FDO handle invalid FGF binary data?
> Jackie,
>  From my experience, I've observed that FDO does not strictly
> validate FGF/WKB input on geometry creation.
> Actually, GeometryFactory checks if WKB stream has minimal length of 9
> bytes and it does not prevent to create geometry from bytes stream of
> garbage.
> Here is a small test of valid and invalid WKB input (see main function):
> http://mateusz.loskot.net/tmp/fdo/test_geometry_factory.cpp.html
> This is the result of 3 test cases included in the test:
> Expected WKT: POINT(15.123 21.456)
> Output WKT  : POINT (-7.84591113289983e+298 0)
> Output WKT  : POINT (15.123 21.456)
> *** FDO Error:
>    *** (.\Src\Geometry\Fgf\GeometryFactory.cpp: 568)
> FDO_1_INVALID_INPUT_ON_CLASS_CREATION
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/How-does-FDO-handle-invalid-fgf-geometries--tp738279p742019.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
