[fdo-users] How does FDO handle invalid fgf geometries?
Dan Stoica dan.stoica at autodesk.com
Fri Aug 22 10:31:53 EDT 2008
Can you please add my findings too? They will be helpful for whoever will fix it.
Thanks.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, August 22, 2008 10:03 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] How does FDO handle invalid fgf geometries?
For reference:
http://trac.osgeo.org/fdo/ticket/382
- Jackie
Dan Stoica wrote:
> This is a bug and needs fixing. It is a bug because GetText() is supposed
> to do a simple dump. What a dump has to do with topological validation?
> None.
> Therefore, filing a ticket is the right thing to do.
> Dan.
> Sent: Thursday, August 21, 2008 11:57 PM
> I strongly suspected that it was some other error than running out of
> memory.
> Good to know my suspicions are confirmed.
> - Jackie
> Dan Stoica wrote:
>> Did some investigations on this matter. Turns out that:
>> a) the polygon in question has a ring which is not closed.
>> b) the geometry factory throws an appropriate exception "Open ring"
>> c) the exception is not caught by GetText()
>> d) for some odd reason the exception is turned into "memory allocation
>> error"
>> Therefore, the quick solution for Jackie is to catch the exception.
>> Going forward, we might want to get rid of the 'is polygon closed?'
>> test...
>> Dan.
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
>> Sent: Thursday, August 21, 2008 10:51 AM
>> To: FDO Users Mail List
>> Subject: Re: [fdo-users] How does FDO handle invalid fgf geometries?
>> Jackie Ng wrote:
>>> Hi All,
>>> How does FDO handle invalid FGF binary data?
>> Jackie,
>>  From my experience, I've observed that FDO does not strictly
>> validate FGF/WKB input on geometry creation.
>> Actually, GeometryFactory checks if WKB stream has minimal length of 9
>> bytes and it does not prevent to create geometry from bytes stream of
>> garbage.
>> Here is a small test of valid and invalid WKB input (see main function):
>> http://mateusz.loskot.net/tmp/fdo/test_geometry_factory.cpp.html
>> This is the result of 3 test cases included in the test:
>> Expected WKT: POINT(15.123 21.456)
>> Output WKT  : POINT (-7.84591113289983e+298 0)
>> Output WKT  : POINT (15.123 21.456)
>> *** FDO Error:
>>    *** (.\Src\Geometry\Fgf\GeometryFactory.cpp: 568)
>> FDO_1_INVALID_INPUT_ON_CLASS_CREATION
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
>> Charter Member of OSGeo, http://osgeo.org
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://n2.nabble.com/How-does-FDO-handle-invalid-fgf-geometries--tp738279p742019.html
> Sent from the FDO Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/How-does-FDO-handle-invalid-fgf-geometries--tp738279p759570.html
More information about the fdo-users mailing list
