[fdo-users] .net and fdo
Greg Boone
greg.boone at autodesk.com
Tue Dec 2 14:52:45 EST 2008
You should be able to use any .Net language.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matteo
Sent: Tuesday, December 02, 2008 2:52 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] .net and fdo
Hi Don,
thanks for your answer. Another things...I can develop with vb.net or only
with C#?
Regards
Donald Cameron wrote:
> Hi Mateo,
> I copy all of the FDO dlls into my bin\Release folder and I reference a
> minimum of three: OSGeo.FDO.dll, OSGeo.FDO.Common.dll, and
> OSGeo.FDO.Geometry.dll. You will have to use C#.
> The SDF connection parameter is File, and the SHP connection parameter is
> DefaultFileLocation. The value of DefaultFileLocation is a folder, which
> contains all of the related SHP files, .shp, .prj, .dbf, etc. An example
> connection string is "DefaultFileLocation=C:\MyData\MyShpFolder;".
> Regards,
> Don
> Sent: Tuesday, December 02, 2008 1:17 PM
> Subject: [fdo-users] .net and fdo
> Hi all, I would to create an application (vb.net or c#) that convert shp
> file to sdf 3. I'm new in fdo tecnology and I don't know the basic step
> for develep with FDO. For example: 1) How dll i must be reference in my
> .net project? 2) What is the connection string to connect to a shp file? I
> don't find some examples Regards Matteo
> ________________________________
> View this message in context: .net and
> fdo<http://n2.nabble.com/.net-and-fdo-tp1605124p1605124.html>
> Sent from the FDO Users mailing list
> archive<http://n2.nabble.com/FDO-Users-f737950.html> at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/.net-and-fdo-tp1605124p1605661.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
