[fdo-users] .net and fdo
Jackie C. Ng
jumpinjackie at gmail.com
Tue Dec 2 17:22:35 EST 2008
Hi Matteo,
You need to use a subversion client to download the code. (eg.
http://tortoisesvn.tigris.org)
- Jackie
Matteo-20 wrote:
> Hi Robert,
> I have try fdotoolbox. It's a very good tool but i don't understand how
> to
> download the code.
> Thanks for the example code.
> Robert Fortin wrote:
>> Hi Matteo!
>> I think the FDO tool box would enable you to copy shp to sdf . See
>> http://fdotoolbox.googlecode.com/ There is also .NET code there to look
>> into.
>> But in order to give you a very brief introduction to get going with .NET
>> FDO...
>> - In order to start you would generally reference OSGeo.Fdo.dll
>> and OSGeo.Fdo.Common.dll (and then add as you need other ones)
>> - You can get the list of available provider from
>> OSGeo.FDO.ClientServices.FeatureAccessManager.GetProviderRegistry()
>> - You will need to get the connection manager from
>> OSGeo.FDO.IconnectionManager
>> mConnMgr=OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager();
>> - Once you know the provider you want to create a connection
>> for,
>> you call CreateConnection on the ConnectionManager for the specific
>> provider named.
>> OSGeo.FDO.Connections.Iconnection mProvConn =
>> mConnMgr.CreateConnection("OSGeo.SDF.3.3");
>> - From the connection, you can get the connection Info object
>> which has the list of connection parameters. This varies depending on the
>> provider.
>> OSGeo.FDO.Connections.IConnectionInfo connInfo =
>> mProvConn.ConnectionInfo;
>> OSGeo.FDO.Connections.IConnectionPropertyDictionary connPropDict =
>> connInfo.ConnectionProperties;
>> connPropDict.SetProperty("File", "myfile");
>> - Once you are done setting the connection parameters, open the
>> connection
>> mProvConn.Open();
>> - From that point on, you can create commands to described the
>> schema
>> OSGeo.FDO.Commands.Schema.IDescribeSchema schemaCmd
>> mProvConn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_DescribeSchema);
>> OSGeo.FDO.Schema.FeatureSchemaCollection schemaCol = schemaCmd.Execute();
>> o Or select/update/delete the data or to retrieve the schema.
>> OSGeo.FDO.Commands.Feature.ISelect selCmd =
>> (OSGeo.FDO.Commands.Feature.ISelect)(OSGeo.FDO.Commands.Feature.ISelectAggregates)mProvConn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select);
>> selCmd.SetFeatureClassName("myclass");
>> OSGeo.FDO.Commands.Feature.IReader myReader = selCmd.Execute();
>> while (myReader.ReadNext())
>> string aStr = myReader.GetString("some_property");
>> Hope this can get you started.
>> Robert
>> From: fdo-users-bounces at lists.osgeo.org
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matteo
>> Sent: Tuesday, December 02, 2008 1:17 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: [fdo-users] .net and fdo
>> Hi all, I would to create an application (vb.net or c#) that convert shp
>> file to sdf 3. I'm new in fdo tecnology and I don't know the basic step
>> for develep with FDO. For example: 1) How dll i must be reference in my
>> .net project? 2) What is the connection string to connect to a shp file?
>> I
>> don't find some examples Regards Matteo
>> ________________________________
>> View this message in context: .net and
>> fdo<http://n2.nabble.com/.net-and-fdo-tp1605124p1605124.html>
>> Sent from the FDO Users mailing list
>> archive<http://n2.nabble.com/FDO-Users-f737950.html> at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://n2.nabble.com/.net-and-fdo-tp1605124p1605707.html
> Sent from the FDO Users mailing list archive at Nabble.com.
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/.net-and-fdo-tp20797931p20802361.html
More information about the fdo-users
