[fdo-users] List of PostGIS tickets we are working on
Bruno Scott
bscott at geomapgis.com
Fri Feb 1 08:50:15 EST 2008
Hi greg
Our unit test are run on AutoCAD Map 3D and Mapguide OpenSource /
Enterprise.
So it will work for sure in map after all the fixes.
One of the things we are not addressing for the moment, is the
LongTransaction support.
Bruno.
gregboone wrote:
> Hi Bruno,
> Within Autodesk we have started a PostGIS Provider evaluation process to
> try and determine the scope of the changes that will be required to make
> the provider usable is products such as AutoCAD Map and AutoCAD MapGuide.
> Once the evaluation is complete, we will forward the results to you.
> Greg
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
> Sent: Thursday, January 31, 2008 8:31 AM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] List of PostGIS tickets we are working on
> Bruno Scott wrote:
>> This is the list of ticket we will fix for sure
>> #94 Generate extent for features assigned to default spatial context
>> #106 PostGIS provider cannot delete a feature class
>> #108 ApplySchema does not support M and Z dims for PostGIS
>> #119 PostGIS missing quotes for columns in queries
>> #121 PostGIS extents calculations do not appear to be working
>> #171 Fdo Postgis Autogenated identity property is mandatory
>> #178 PostGIS : Can't insert in a non-feature class
>> #232 Fdo Postgis null and not null filter does not work
>> #233 Fdo Postgis in and not in filter does not work
>> #234 Fdo Postgis currently does not support anything but lowercase
>> identifiers
>> #235 Fdo Postgis Exception with insert
>> #236 Fdo Postgis does not support non spatial classes
>> #241 Implement Support for SelectAggregates, SpatialExtents and Count
> Bruno,
> I'd like to thank you so much for helping in development of the PostGIS
> provider. That's fantastic. If there is anything unclear or you will
> need assistance regarding current codebase of the PostGIS provider,
> please don't hesitate to contact me directly (Skype: mloskot)
> or here on the list (though I'm not reading it carefully ATM).
>> Not sure about these one
>> #122 Add PostGIS Samples to SVN
> This is low-priority task and I think I'm the only one who can fix it.
>> #120 PostGIS ungracefully handles structural problems in a database
> This ticket is about inventing a way to detect and report low-level
> problems like missing missing columns or missing postgis installation,
> etc. in user-friendly way.
>> #117 PostGIS provider does not display attribute names in MapGuide when
>> no
>> PK present
> I'm not sure about this one too.
> Jason, I'm not sure what does the "not available for display as
> properties" mean. Where is the "display"? Display as label or some
> MapGuide widgest/boxes, or in MapStudio?
>> We have our own unit test engine that does a lot of stuf,
>> For the moment we can't really go in deep because of too much tickets
>> Once we will have these repaired we will find others for sure and we will
>> fix them...
> Bruno, I'm very thankful for your contributions!
> I'll be back to the PostGIS provider development as soon as I have my
> study issues done, hopefully within a few weeks.
> Best regards
> Mateusz Loskot
> http://mateusz.loskot.net
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/List-of-PostGIS-tickets-we-are-working-on-tp15201258s18162p15226898.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
