[fdo-users] PostGIS : new feature class naming proposition
Artem Dolya
Artem.Dolya at ambercore.com.ua
Wed Feb 13 08:30:31 EST 2008
How can I move it to the internal list?
Thanks forward
----- Original Message -----
To: "FDO Internals Mail List" <fdo-internals at lists.osgeo.org>
Cc: "FDO Users Mail List" <fdo-users at lists.osgeo.org>
Sent: Tuesday, February 12, 2008 8:22 PM
Subject: RE: [fdo-users] PostGIS : new feature class naming proposition
Hi Bruno,
I'd suggest moving this conversation to the FDO-internals list, as it is
supposed to be more focussed on core development.
I can't think of any draw-backs to this approach. Are there any cases
where a feature class becomes disassociated from its connection and you
have to work your way backwards? Or you would need to access a
different schema from that connection? I'm thinking probably not...
I'm thinking that not having the schema name in the feature class will
potentially make transferring feature classes from one schema or
database to another easier (using Fdo2Fdo or something similar).
Jason
-----Original Message-----
Subject: [fdo-users] PostGIS : new feature class naming proposition
We are actively debugging the postgis provider.
And i have a proposal for the featureclass name
Actually , on the connection string we specify the datastore.
As this datastore is phycally the schema name so there is no need to
include
it in the featureclass name
So i suggest to get rid of this schema name but to keep backward
compatibility
So if someone use an fdo function having a featureclass name as an input
parameters
both "schema~table" or "table" will work
but if we ask the provider to give us the list of featureclass name
it will only return "table"
Is that ok?
Bruno
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
__________ NOD32 2858 (20080208) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
?? ??N??????»N??·N?N? ?±?µN????»?°N???N?N? ???µN?N???N? SPAMfighter ???»N? N??°N?N???N?N? ?????»N??·?????°N??µ?»?µ??.
??N?????N??°?????° N????°?»???»?° 1409 N??». ????N?N????° N????°???°, ?????»N?N??µ????N??µ ???? ???°N?N???N?N??µ???? ??N??µ???µ????.
?????»N??·?????°N??µ?»?? ???»?°N??????? ???µN?N????? ???µ ?????µN?N? N?N??????? N??????±N??µ????N? ?? ??N? N??»?µ??N?N???????N?N? ????N?N????°N?.
??????N????±?????°N?N?:http://www.spamfighter.com/lru
More information about the fdo-users
