[fdo-users] FDO SDF Defect : can't filter on date
    Bruno Scott
    bscott at geomapgis.com
    Thu Jan  3 06:34:42 EST 2008
Thanks for the reply
I have made some testing with you suggestion
I have try this
select MYKEY from MYTABLE where MYDATE = TIMESTAMP '2007-01-01 00:00:00'
and it return the expected result ( only one record)
i have also try this one
select MYKEY from MYTABLE where MYDATE = DATE '2007-01-01'
and it return no record
I was on the way and i have also tried order stuf
My test database have 100 records
starting with 2007-01-01 then 2007-01-02 and so on
select MYKEY from MYTABLE where MYDATE > TIMESTAMP '2007-01-01 00:00:00'
no record are returned ( should be 99 records in my test database)
select MYKEY from MYTABLE where MYDATE >= TIMESTAMP '2007-01-01 00:00:00'
1 record is returned ( should be 100 records in my test database)
select MYKEY from MYTABLE where MYDATE < TIMESTAMP '2007-01-01 00:00:00'
99 record is returned ( All record except the one that is 2007-01-01)
select MYKEY from MYTABLE where MYDATE <= TIMESTAMP '2007-01-01 00:00:00'
100 record is returned ( All record are returned)
all these test return the expected result with the MySQL provider
and they are using the exact same code
Romica Dascalescu wrote:
> You should use one of the keywords depending of the provided text content
> DATE                    - in case you have only a date (your case)
> TIME                    - in case you have only a time
> TIMESTAMP               - in case you have a datetime
> E.G.:
> FdoFilter::Parse(L"MYDATE = DATE '2007-01-01'")
> Romy.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
> Sent: Wednesday, January 02, 2008 11:12 AM
> To: FDO Users Mail List
> Subject: RE: [fdo-users] FDO SDF Defect : can't filter on date
> You should be using the string format of the FdoDateTime class as:
> select->SetFilter(FdoPtr<FdoFilter>(FdoFilter::Parse(L"datetime =
> TIMESTAMP '2006-04-21 19:40:10.0001'")));
> The above line is taken from the SDF provider unit test.
> Badreddine
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Wednesday, January 02, 2008 8:32 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO SDF Defect : can't filter on date
> I try to execute this type of query
> select MYKEY from MYTABLE where MYDATE = 2007-01-01'
> The query execution works fine but as soon as i try to fetch the first
> record
> i got this exception "Cannot convert string to DateTime"
> Sample code:
> FdoPtr<FdoISelect>            sampleSelect;
> FdoPtr<FdoIFeatureReader> sampleFeatureReader;
> sampleSelect = (FdoISelect
> *)m_connection->CreateCommand(FdoCommandType_Select);
> sampleSelect->SetFeatureClassName(_T("MYTABLE"));
> sampleSelect->SetFilter(_T("MYDATE = 2007-01-01'"));
> FdoPtr<FdoIdentifier>queryPropertyName =
> FdoIdentifier::Create(_T("MYKEY"));
> FdoPtr<FdoIdentifierCollection> propertyCollection =
> sampleSelect->GetPropertyNames();
> propertyCollection->Add(queryPropertyName);
> sampleFeatureReader = sampleSelect->Execute();
> sampleFeatureReader->ReadNext() // this line throw the exception
> I have the same problem if i use FdoISelectAggregates
> Bruno
> http://www.nabble.com/FDO-SDF-Defect-%3A-can%27t-filter-on-date-tp14578427s18162p14578427.html
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/FDO-SDF-Defect-%3A-can%27t-filter-on-date-tp14578427s18162p14595571.html
More information about the fdo-users
