[fdo-users] Is there a Feature class naming convention
Bruno Scott bscott at geomapgis.com
Tue Jan 22 11:54:54 EST 2008
When i query the className against the OGR PostGIS
it returns : MySchema~MyTable
When i query the className against the King.Oracle
it returns : MySchema~MyTable~myGeometryColumn
So if classname should be "MyTable" and fully qualified name
"MySchema:MyTable"
Can we consider this as a bug in these 2 providers?
Orest Halustchak wrote:
> I'm not sure why these providers would change the class names this way.
> From FDO you can ask for class name and fully qualified class name
> separately so there should be no need to change the class name this way.
> Class name should come back as "MyFeatureClass" and fully qualified class
> name should come back as "MySchema:MyFeatureClass".
> Thanks,
> Orest.
> ------Original Message------
> From: Bruno Scott
> To: fdo-users at lists.osgeo.org
> ReplyTo: FDO Users Mail List
> Sent: Jan 22, 2008 10:33 AM
> Subject: [fdo-users] Is there a Feature class naming convention
> When we create a feature class, let say using the MySQL provider we give a
> feature class name example: "MyFeatureClass"
> and when we query it we use the same "MyFeatureClass"
> This is fine...
> With the PostGIS provider, we create the feature with a name like
> "MyFeatureClass"
> but we query with a different name example "MySchema.MyFeatureClass"
> We have this same problem with the King.Oracle provider
> When you have an application that uses any FDO RDBMS provider, it makes
> things very difficult to handle.
> We need to hardcode
> "if provider == PostGis" then
> "if provider == KingOracle then
> And it is a bit against the FDO philosophy, a single language to address
> the
> same way any spatial database,file
> It there a reason for that different naming?
> Bruno Scott
> http://www.nabble.com/Is-there-a-Feature-class-naming-convention-tp15021175s18162p15021175.html
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Sent from my BlackBerry Wireless Handheld
View this message in context: http://www.nabble.com/Is-there-a-Feature-class-naming-convention-tp15021175s18162p15023058.html
More information about the fdo-users mailing list
