[fdo-users] Error in OSGeo.SHP.3.2
Traian Stanev
traian.stanev at autodesk.com
Thu Jan 24 18:36:17 EST 2008
Not a bug, but very confusing nonetheless. The GEOMETRIC property type is one of:
/// \ingroup (enums)
/// \brief
/// The FdoGeometricType enumeration categorizes all of the geometry types
/// supported by FDO based on their geometric dimensionality.
enum FdoGeometricType
/// Represents 0-dimensional geometric primitives, such as Points.
FdoGeometricType_Point = 0x01,
/// Represents 1 dimensional geometric primitives, such as Curves and Lines.
FdoGeometricType_Curve = 0x02,
/// Represents 2 dimensional geometric primitives, such as Polygons.
FdoGeometricType_Surface = 0x04,
/// Represents 3 dimensional geometric primitives, such as Cubes.
FdoGeometricType_Solid = 0x08
This is not the same as the GEOMETRY type of the actualy geometry returned by FdoIFeatureReader::GetGeometry(), which is one of:
#ifdef __cplusplus
/// \brief
/// FdoGeometryType is an enumeration to denote the type of a Geometry.
/// \remarks
/// This enumeration applies to types that derive from FdoIGeometry.
enum FdoGeometryType
#else
typedef enum
#endif
/// Indicates no specific type; used for "unknown", "don't care" or an incompletely constructed Geometry object.
FdoGeometryType_None = 0,
/// Point type (FdoIPoint).
FdoGeometryType_Point = 1,
/// LineString type (FdoILineString).
FdoGeometryType_LineString = 2,
/// Polygon type (FdoIPolygon).
FdoGeometryType_Polygon = 3,
/// MultiPoint type (FdoIMultiPoint).
FdoGeometryType_MultiPoint = 4,
/// MultiLineString type (FdoIMultiLineString).
FdoGeometryType_MultiLineString = 5,
/// MultiPolygon type (FdoIMultiPolygon).
FdoGeometryType_MultiPolygon = 6,
/// MultiGeometry type (FdoIMultiGeometry).
FdoGeometryType_MultiGeometry = 7,
/// CurveString type (FdoICurveString).
FdoGeometryType_CurveString = 10,
/// CurvePolygon type (FdoICurvePolygon).
FdoGeometryType_CurvePolygon = 11,
/// MultiCurveString type (FdoIMultiCurveString).
FdoGeometryType_MultiCurveString = 12,
/// MultiCurvePolygon type (FdoIMultiCurvePolygon).
FdoGeometryType_MultiCurvePolygon = 13
#ifdef __cplusplus
#else
} FdoGeometryType;
#endif
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Chris Erickson [chris at spatialdatatech.com]
Sent: Thursday, January 24, 2008 6:15 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Error in OSGeo.SHP.3.2
Hello,
I’m using FDO 3.2 and connecting to a Polygon shape file of US Counties (using the DotNet interops). When I get the geometry property of the counties feature class, the GeometryTypes member is 4 (MultiPoint). This should be 3 (polygon). Does anybody know why this is happening, or is it just a bug?
-Chris
More information about the fdo-users
