[fdo-users] OGR 3.3 Provider runtime error
Traian Stanev
traian.stanev at autodesk.com
Thu Jan 24 23:07:28 EST 2008
Depends can export the dependency graph to a file. If you could export yours and send it over I can take a quick look. Since the file can be large, email it to me only.
Traian
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, January 24, 2008 11:04 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
That is correct, there are no red C++ functions listed.
- Jackie
Traian Stanev wrote:
> So, you open depends for OGRProvider.dll, pick FDO.dll from the tree-view
> on the top left, and then look on the right side. It will show functions
> from FDO.dll that the OGRProvider calls. Most of them will have a green
> "C++" next to them. Are you saying none of them have a red C++ if you do
> this?
> Traian
>> Sent: Tuesday, January 22, 2008 3:03 AM
>> I've combed through the list of functions (OGRProvider.dll and directly
>> related dlls) and couldn't find any red ones. However the log window
>> did say
>> there was at least one unresolved export function in one of the delay-
>> load
>> dependent modules, but it doesn't say which one??
>> - Jackie
>> > DWMAPI.dll is a common false positive that depends throws. That's not
>> your
>> > actual problem.
>> > In depends, look in one of the right panes (the one in the middle,
>> not the
>> > top right), where it lists all the dependent DLL functions that are
>> needed
>> > by the provider. See if any of them are listed in red.
>> > Traian
>> > ________________________________________
>> > [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> > [jackie.ng at aecsystems.com.au]
>> > Sent: Monday, January 21, 2008 11:49 PM
>> > Subject: [fdo-users] OGR 3.3 Provider runtime error
>> > Hi List,
>> > I have an application that interrogates a provider's connection
>> > properties,
>> > but when I want to get the connection properties of the OGR provider.
>> I
>> > get
>> > the following error:
>> > Microsoft Visual C++ Runtime Library
>> > Runtime Error!
>> > Program: [path to executable]
>> > R6034
>> > An Application has made an attempt to load the C runtime library
>> > incorrectly.
>> > Please contact the application's support team for more information.
>> > If I run this through the vs debugger, I get an unhandled
>> > OSGeo.FDO.Common.Exception with the following message.
>> > "Unable to load the FDO Provider: A dynamic link library (DLL)
>> > initialization routine failed."
>> > Running OGRProvider.dll through depends.exe, I found that it was has
>> a
>> > missing dependency dwmapi.dll, which after some googling turns out to
>> be a
>> > Windows Vista dll (???). So I downloaded the file anyway, and put it
>> into
>> > the working directory, but I still get the same error messages.
>> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows
>> XP.
>> > I am using the managed dlls.
>> > Any ideas?
>> > - Jackie
>> > View this message in context:
>> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
>> tp15012644s18162p15012644.html
>> > Sent from the fdo-users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
>> runtime-error-tp15012644s18162p15014222.html
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15080594.html
More information about the fdo-users
