[fdo-users] Error in OSGeo.SHP.3.2
Chris Erickson
chris at spatialdatatech.com
Mon Jan 28 14:27:30 EST 2008
Dan,
Sorry, I'll just explain my whole scenario.
I have a MySql 5.0 instance set up and I imported a plain counties polygon
shapefile. I'm trying to query the database to find out what kind of
features that table stores (via. FDO), and it is returning a 7 (which
apparently indicates that it stores Point, Line or Polygon).
Is there a way to figure out what type of features that specific layer
stores, or is that 1 layer not 'strongly typed' in MySql? If not, is there
a way to build layers which only store a specific geometry type in mysql?
-Chris
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Monday, January 28, 2008 12:11 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] Error in OSGeo.SHP.3.2
" the GeometryTypes member doesn't return the type of geometry"
Do you mean it returns a 0 (zero)? Did you SetGeometryTypes() on that
class?
What exactly is the scenario?
Thanks,
Dan.
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Chris Erickson
Sent: Monday, January 28, 2008 1:44 PM
To: 'FDO Users Mail List'
I'll do that.
Does anybody have thoughts on my 2nd question?
2) If I have a GeometricPropertyDefinition that belongs to a feature class,
and the GeometryTypes member doesn't return the type of geometry the
property stores, where do I find out this information?
Thanks,
Chris
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Friday, January 25, 2008 1:35 PM
Please log a trac item on trac.osgeo.org/fdo.
Greg
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Clayton Hotson
Sent: Friday, January 25, 2008 2:49 PM
Hi Chris,
I've noticed this as well - for some reason this enum is not exposed in the
managed wrappers.
You can define it yourself though - something like:
public enum GeometricType
GeometricType_Point = 1,
GeometricType_Curve = 2,
GeometricType_Surface = 4,
GeometricType_Solid = 8,
GeometricType_All = 1 | 2 | 4 | 8
I hope this helps!
Clayton
Sent: Friday, January 25, 2008 4:36 PM
Traian,
Thanks for the insight. That helps a lot.
A few more questions (for anyone)
1) I'm using the DotNET API, and I can't find the GeometricType enumeration.
Do you know where it is exposed?
3) If I use IFeatureReader::GetGeometry(), it returns an FGF binary,
correct?
Thanks for the help,
Chris
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Thursday, January 24, 2008 4:36 PM
Not a bug, but very confusing nonetheless. The GEOMETRIC property type is
one of:
/// \ingroup (enums)
/// \brief
/// The FdoGeometricType enumeration categorizes all of the geometry types
/// supported by FDO based on their geometric dimensionality.
enum FdoGeometricType
/// Represents 0-dimensional geometric primitives, such as Points.
FdoGeometricType_Point = 0x01,
/// Represents 1 dimensional geometric primitives, such as Curves and
Lines.
FdoGeometricType_Curve = 0x02,
/// Represents 2 dimensional geometric primitives, such as Polygons.
FdoGeometricType_Surface = 0x04,
/// Represents 3 dimensional geometric primitives, such as Cubes.
FdoGeometricType_Solid = 0x08
This is not the same as the GEOMETRY type of the actualy geometry returned
by FdoIFeatureReader::GetGeometry(), which is one of:
#ifdef __cplusplus
/// \brief
/// FdoGeometryType is an enumeration to denote the type of a Geometry.
/// \remarks
/// This enumeration applies to types that derive from FdoIGeometry.
enum FdoGeometryType
#else
typedef enum
#endif
/// Indicates no specific type; used for "unknown", "don't care" or an
incompletely constructed Geometry object.
FdoGeometryType_None = 0,
/// Point type (FdoIPoint).
FdoGeometryType_Point = 1,
/// LineString type (FdoILineString).
FdoGeometryType_LineString = 2,
/// Polygon type (FdoIPolygon).
FdoGeometryType_Polygon = 3,
/// MultiPoint type (FdoIMultiPoint).
FdoGeometryType_MultiPoint = 4,
/// MultiLineString type (FdoIMultiLineString).
FdoGeometryType_MultiLineString = 5,
/// MultiPolygon type (FdoIMultiPolygon).
FdoGeometryType_MultiPolygon = 6,
/// MultiGeometry type (FdoIMultiGeometry).
FdoGeometryType_MultiGeometry = 7,
/// CurveString type (FdoICurveString).
FdoGeometryType_CurveString = 10,
/// CurvePolygon type (FdoICurvePolygon).
FdoGeometryType_CurvePolygon = 11,
/// MultiCurveString type (FdoIMultiCurveString).
FdoGeometryType_MultiCurveString = 12,
/// MultiCurvePolygon type (FdoIMultiCurvePolygon).
FdoGeometryType_MultiCurvePolygon = 13
#ifdef __cplusplus
#else
} FdoGeometryType;
#endif
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org]
On Behalf Of Chris Erickson [chris at spatialdatatech.com]
Sent: Thursday, January 24, 2008 6:15 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Error in OSGeo.SHP.3.2
Hello,
I'm using FDO 3.2 and connecting to a Polygon shape file of US Counties
(using the DotNet interops). When I get the geometry property of the
counties feature class, the GeometryTypes member is 4 (MultiPoint). This
should be 3 (polygon). Does anybody know why this is happening, or is it
just a bug?
-Chris
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
