[fdo-users] InCondition on Select not working as expected
Chris Erickson
chris at spatialdatatech.com
Mon Jan 28 17:02:58 EST 2008
Hello,
I'm trying to pull a specific set of records out of a table (In MySQL) using
an InCOndition and an ISelect command.
I'm getting an error 'Expected object or association property' when I call
ISelect->Execute(), and am not sure why.
Here is a code snippet:
//_connection is a MySql 3.2 connection
//_featureClass is a FeatureClass
//SelectByAttribute is a DataProperty (of _featureClass)
//values is a DotNet List<string>
ISelect command =
(ISelect)_connection.CreateCommand(CommandType.CommandType_Select);
command.Filter = new
InCondition(selectByAttribute.QualifiedName, values.ToArray());
command.SetFeatureClassName(_featureClass.QualifiedName);
command.Prepare();
_dataReader = command.Execute(); // <-- this line gives
"Expected object or association property" exception
-Chris
More information about the fdo-users
