[fdo-users] FDO provider under Linux
gimbrogno magnitudo9 at email.it
Fri Jul 4 04:49:31 EDT 2008
Hi all,
I have a problem with PostGIS FDO provider when I try to connect Mapguide to
the database... I'm not yet been able to solve this problem and since there
is too little time I would to ask you what is the most used Db source and
the best provider to connect Mapguide to the db. I am using Mapguide 2.0.1
and FDO 3.3.1, my O.S. is Linux CentOS 5 and I have to create some spatial
tables to contain POIs that will be to placed on a layer upon a default
layer on a shapefile.
Thanks a lot in advance...
View this message in context: http://www.nabble.com/FDO-provider-under-Linux-tp18275524p18275524.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
