[fdo-users] SQL Server 2008 layers not rendering in Mapguide
Bill Ten Broeck
btenbroeck at gmail.com
Wed Jul 9 10:39:11 EDT 2008
Hey Brent.
Yes. The first error is when I simply try to view the data:
<2008-07-09T10:26:05> Administrator
Error: Failed to stylize layer: FloorPlans_SQLSpatial_FMWeb
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot
call methods on image.
StackTrace:
- MgMappingUtil.StylizeLayers line 776 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\mapping\MappingUtil.cpp
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot call
methods on image.
This second one is if I try just for giggles to select non-existent
entities; btw, the geometry column shows up in Studio:
<2008-07-09T10:28:08> Administrator
Error: An exception occurred in FDO component.
find either column "geometry" or the user-defined function or aggregate
"geometry.STIntersects", or the name is ambiguous.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute line 125 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 647 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection line 1252 file
- MgServerSelectFeatures.SelectFeatures line 249 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\ServerSelectFeatures.cpp
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot find either
<2008-07-09T10:30:39>
Brent Robinson wrote:
> Hi Bill,
> Do any messages show up in Error.log when you try to draw the features in MapGuide?
> Brent.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bill Ten Broeck
> Sent: Monday, June 30, 2008 6:49 AM
> To: FDO Users Mail List
> Subject: [fdo-users] SQL Server 2008 layers not rendering in Mapguide
> I populated SQL Server 2008 with some data, using both Map 2009 and FME.
> Map can render both sets of data, as can FME universal viewer. Mapguide
> however does not. Mapguide sees the data in Studio, picks up the
> coordinate system (arbitrary xy) and allows creation of a layer.
> However, once I try to view the layer in a layout - nothing. The layer
> appears in the TOC, but nothing renders in the Map. I threw a PK on the
> table just for grins.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
