[fdo-users] FDO doesn't compile on Debian Linux
mike at malagatech.com
Tue Jul 29 21:46:10 EDT 2008
The second "O" in Source is a typo; the path being used is correct.
Mike
On Tue, 29 Jul 2008 15:36:30 -0700, Jack Lee <jack.lee at autodesk.com> wrote:
> Hi,
> Is /usr/local/src/OpenSOurce_FDO the correct directory? Notice the second
> capital O in OpenSOurce_FDO?
> make[2]: *** No rule to make target
> '/usr/local/src/OpenSOurce_FDO/Utilities/Common/libProviderCommon.la',
> needed by 'UnitTest'. Stop.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
> Sent: Tuesday, July 29, 2008 5:42 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO doesn't compile on Debian Linux
> I have downloaded version 3.3.1 of FDO to my Debian Linux system. I'm
> running the current stable distribution of Debian with the latest
> updates.
> I believe I have installed of the required Debian packages to be able to
> build and install FDO. In addition to the base FDO source I also
> downloaded the following providers: ArcSDE, GDAL, GenericRdbms, SHP. I
> am
> able to run "source setenvironment.sh" without an error. I am able to
> run
> "./build_thirdparty.sh" without an error. When I try to run
> "./build_linux.sh" or "./build_linux.sh --c release --a buildinstall --m
> configure --w all" the process works for a while and then dies with the
> error:
> make[2]: Leaving directory
> '/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
> make[1]: *** [install-recursive] Error 1
> make[1]: Leaving directory
> '/usr/local/src/OpenSource_FDO/Providers/GDAL/Src'
> make: *** [install-recursive] Error 1
> Any help would be appreciated,
> Thank you,
> Mike Juneau
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
