[fdo-users] FDO doesn't compile on Debian Linux
Jack Lee
jack.lee at autodesk.com
Wed Jul 30 07:30:55 EDT 2008
Did you run build_parse.sh? You shouldn't need to run the script.
You should verify that the files under Utilities/Common/Inc/Parse and Utilities/Common/Src/Parse did not changed.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of mike at malagatech.com
Sent: Wednesday, July 30, 2008 12:06 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] FDO doesn't compile on Debian Linux
I think that may be where the problem is. It enters Utilities/Common and
begin compiling but then has errors on the following files:
yyConstraint.h, yyConstraint.y, yyConstraint.cpp
Below is the complete output from my build process:
configuring fdocore
acinclude.m4:7: warning: underquoted definition of FDO_HELP_STRING
acinclude.m4:7: run info '(automake)Extending aclocal'
acinclude.m4:7: or see
http://sources.redhat.com/automake/automake.html#Extending-aclocal
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for bison... bison -y
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
yes
appending configuration tag "F77" to libtool
configure: Building with default location of FDO API files at
/usr/local/src/OpenSource_FDO/Fdo
configure: Building with default location of FDO Utility files at
/usr/local/src/OpenSource_FDO/Utilities
configure: Building with default location of FDO Thirdparty files at
/usr/local/src/OpenSource_FDO/Thirdparty
configure: Using optimized configuration
configure: creating ./config.status
config.status: creating Makefile
config.status: creating Fdo/Makefile
config.status: creating Utilities/Makefile
config.status: creating Thirdparty/Makefile
config.status: creating Fdo/Unmanaged/Makefile
config.status: creating Fdo/Unmanaged/Src/Makefile
config.status: creating Fdo/Unmanaged/Src/McToMsf/Makefile
config.status: creating Fdo/Unmanaged/Src/Message/Makefile
config.status: creating Fdo/Unmanaged/Src/FileToHdr/Makefile
config.status: creating Fdo/Unmanaged/Src/Nls/Makefile
config.status: creating Fdo/Unmanaged/Src/Common/Makefile
config.status: creating Fdo/Unmanaged/Src/Geometry/Makefile
config.status: creating Fdo/Unmanaged/Src/Spatial/Makefile
config.status: creating Fdo/Unmanaged/Src/Fdo/Makefile
config.status: creating Fdo/Unmanaged/Inc/Makefile
config.status: creating Fdo/Managed/Makefile
config.status: creating Fdo/Install/Makefile
config.status: creating Fdo/Install/XsdInstallPaths/Makefile
config.status: creating Fdo/Docs/Makefile
config.status: creating Fdo/Docs/doc_src/Makefile
Fdo/Docs/doc_src/group_and_page_definitions/Makefile
config.status: creating Fdo/Docs/doc_src/headers_and_footers/Makefile
config.status: creating Fdo/Docs/XmlSchema/Makefile
config.status: creating Fdo/UnitTest/Makefile
config.status: creating Utilities/Common/Makefile
config.status: creating Utilities/TestCommon/Makefile
config.status: creating Utilities/SQLiteInterface/Makefile
config.status: creating Utilities/OWS/Makefile
config.status: creating Utilities/OWS/Src/Makefile
config.status: creating Utilities/ExpressionEngine/Makefile
config.status: creating Utilities/ExpressionEngine/Src/Makefile
config.status: creating Utilities/ExpressionEngine/Inc/Makefile
config.status: creating Utilities/SchemaMgr/Makefile
config.status: creating Utilities/SchemaMgr/Inc/Makefile
config.status: creating Utilities/SchemaMgr/Nls/Makefile
config.status: creating Utilities/SchemaMgr/Src/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Lp/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ov/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Cfg/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Mt/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Rb/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile
config.status: executing depfiles commands
Making all in Fdo
make[1]: Entering directory `/usr/local/src/OpenSource_FDO/Fdo'
Making all in Unmanaged
make[2]: Entering directory `/usr/local/src/OpenSource_FDO/Fdo/Unmanaged'
Making all in Src
make[3]: Entering directory
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src'
Making all in McToMsf
make[4]: Entering directory
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/McToMsf'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory
Making all in Message
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/Message'
Making all in FileToHdr
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/FileToHdr'
Making all in Nls
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/Nls'
Making all in Common
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/Common'
Making all in Geometry
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/Geometry'
/bin/sh ../../../../libtool --tag=CXX --mode=compile g++
-DPACKAGE_NAME=\"FDO\" -DPACKAGE_TARNAME=\"fdo\"
-DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"FDO\ 3.3.0\"
-DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdo\"
-DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
-DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1
-DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
-DHAVE_DLFCN_H=1 -I. -I../../Inc -I../Common -O2 -MMD -MT -DFULLPROTO
-D__USE_GNU -MT yyFgft.lo -MD -MP -MF .deps/yyFgft.Tpo -c -o yyFgft.lo
`test -f 'Parse/yyFgft.cpp' || echo './'`Parse/yyFgft.cpp
g++ -DPACKAGE_NAME=\"FDO\" -DPACKAGE_TARNAME=\"fdo\"
-DPACKAGE_VERSION=\"3.3.0\" "-DPACKAGE_STRING=\"FDO 3.3.0\""
-D__USE_GNU -MT yyFgft.lo -MD -MP -MF .deps/yyFgft.Tpo -c Parse/yyFgft.cpp
-fPIC -DPIC -o .libs/yyFgft.o
Fdo/Unmanaged/Src/Geometry/Parse/yyFgft.y:40: error: invalid function
declaration
y.tab.h:114: error: declaration does not declare anything
Parse/ParseFgft.h:124: error: field 'fdo_fgft_yyval' has incomplete type
Parse/ParseFgft.h:125: error: field 'fdo_fgft_yylval' has incomplete type
yyFgft.cpp:341: error: expected ';' before '->' token
yyFgft.cpp:342: error: field 'pParse' has incomplete type
yyFgft.cpp:342: error: expected ';' before '->' token
yyFgft.cpp:1159: error: expected ',' or '...' before '->' token
yyFgft.cpp: In function 'void fdo_fgft_yydestruct(const char*, int,
FDO_FGFT_YYSTYPE*)':
yyFgft.cpp:1168: error: invalid use of undefined type 'union
FDO_FGFT_YYSTYPE'
Parse/yyFgft.h:106: error: forward declaration of 'union FDO_FGFT_YYSTYPE'
yyFgft.cpp: In function 'int fdo_fgft_yyparse()':
yyFgft.cpp:1260: error: expected initializer before '->' token
yyFgft.cpp:1261: error: expected initializer before '->' token
yyFgft.cpp:1264: error: elements of array 'FDO_FGFT_YYSTYPE fdo_fgft_yyvsa
[200]' have incomplete type
yyFgft.cpp:1264: error: storage size of 'fdo_fgft_yyvsa' isn't known
yyFgft.cpp:1265: error: expected initializer before '->' token
yyFgft.cpp:1271: error: expected initializer before '->' token
yyFgft.cpp:1285: error: 'pParse' was not declared in this scope
yyFgft.cpp:1350: error: invalid application of 'sizeof' to incomplete type
'FDO_FGFT_YYSTYPE'
yyFgft.cpp:1353: error: 'union fdo_fgft_yyalloc' has no member named
'pParse'
'pParse'
yyFgft.cpp:1354: error: 'union fdo_fgft_yyalloc' has no member named
'fdo_fgft_yyvs'
yyFgft.cpp:1354: error: 'fdo_fgft_yyvs' was not declared in this scope
'fdo_fgft_yyvs'
Parse/ParseFgft.h:171: error: too few arguments to function 'FdoInt32
fdo_fgft_yylex(FdoParseFgft*)'
yyFgft.cpp:1397: error: at this point in file
yyFgft.cpp:1784: error: cannot convert 'const char*' to 'FdoParseFgft*' for
argument '1' to 'FdoInt32 fdo_fgft_yyerror(FdoParseFgft*, char*)'
yyFgft.cpp:1930: error: cannot convert 'const char*' to 'FdoParseFgft*' for
make[4]: *** [yyFgft.lo] Error 1
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/src/OpenSource_FDO/Fdo/Unmanaged'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/OpenSource_FDO/Fdo'
make: *** [all-recursive] Error 1
Making install in Fdo
Making install in Unmanaged
Making install in Src
Making install in McToMsf
make[5]: Entering directory
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Nothing to be done for `install-data-am'.
make[5]: Leaving directory
Making install in Message
Making install in FileToHdr
Making install in Nls
Making install in Common
Making install in Geometry
declaration
FDO_FGFT_YYSTYPE'
'FDO_FGFT_YYSTYPE'
'pParse'
'pParse'
'fdo_fgft_yyvs'
'fdo_fgft_yyvs'
make[3]: *** [install-recursive] Error 1
make[2]: *** [install-recursive] Error 1
make[1]: *** [install-recursive] Error 1
make: *** [install-recursive] Error 1
`/usr/local/src/OpenSource_FDO/Utilities/Common'
/bin/sh ../../libtool --tag=CXX --mode=compile g++ -DPACKAGE_NAME=\"FDO\"
-DPACKAGE_TARNAME=\"fdo\" -DPACKAGE_VERSION=\"3.3.0\"
-DHAVE_DLFCN_H=1 -I. -I/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Inc
-I./Inc -I/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/Common -O2
-MMD -MT -D__USE_GNU -DLINUX -DLINUX_IA32 -pthread -DHAVE_GEOM_INFO_TYPE
-MT yyConstraint.lo -MD -MP -MF .deps/yyConstraint.Tpo -c -o
yyConstraint.lo `test -f 'Src/Parse/yyConstraint.cpp' || echo
'./'`Src/Parse/yyConstraint.cpp
-I./Inc -I/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/Common -O2 -MMD
-MT -D__USE_GNU -DLINUX -DLINUX_IA32 -pthread -DHAVE_GEOM_INFO_TYPE -MT
Src/Parse/yyConstraint.cpp -fPIC -DPIC -o .libs/yyConstraint.o
In file included from ./Inc/Parse/Lex.h:38,
from ./Inc/Parse/Parse.h:33,
from Utilities/Common/Src/Parse/yyConstraint.y:48:
./Inc/Parse/yyConstraint.h:5:1: warning: "FdoToken_NULL" redefined
Src/Parse/yyConstraint.cpp:127:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:6:1: warning: "FdoToken_TRUE" redefined
Src/Parse/yyConstraint.cpp:128:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:7:1: warning: "FdoToken_FALSE" redefined
Src/Parse/yyConstraint.cpp:129:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:8:1: warning: "FdoToken_DATE" redefined
Src/Parse/yyConstraint.cpp:130:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:9:1: warning: "FdoToken_TIME" redefined
Src/Parse/yyConstraint.cpp:131:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:10:1: warning: "FdoToken_TIMESTAMP" redefined
Src/Parse/yyConstraint.cpp:132:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:11:1: warning: "FdoToken_GEOMFROMTEXT" redefined
Src/Parse/yyConstraint.cpp:133:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:12:1: warning: "FdoToken_AND" redefined
Src/Parse/yyConstraint.cpp:134:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:13:1: warning: "FdoToken_OR" redefined
Src/Parse/yyConstraint.cpp:135:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:14:1: warning: "FdoToken_NOT" redefined
Src/Parse/yyConstraint.cpp:136:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:15:1: warning: "FdoToken_LIKE" redefined
Src/Parse/yyConstraint.cpp:137:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:16:1: warning: "FdoToken_IN" redefined
Src/Parse/yyConstraint.cpp:138:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:17:1: warning: "FdoToken_BEYOND" redefined
Src/Parse/yyConstraint.cpp:139:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:18:1: warning: "FdoToken_WITHINDISTANCE"
redefined
Src/Parse/yyConstraint.cpp:140:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:19:1: warning: "FdoToken_CONTAINS" redefined
Src/Parse/yyConstraint.cpp:141:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:20:1: warning: "FdoToken_COVEREDBY" redefined
Src/Parse/yyConstraint.cpp:142:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:21:1: warning: "FdoToken_CROSSES" redefined
Src/Parse/yyConstraint.cpp:143:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:22:1: warning: "FdoToken_DISJOINT" redefined
Src/Parse/yyConstraint.cpp:144:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:23:1: warning: "FdoToken_ENVELOPEINTERSECTS"
redefined
Src/Parse/yyConstraint.cpp:145:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:24:1: warning: "FdoToken_EQUALS" redefined
Src/Parse/yyConstraint.cpp:146:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:25:1: warning: "FdoToken_INTERSECTS" redefined
Src/Parse/yyConstraint.cpp:147:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:26:1: warning: "FdoToken_INSIDE" redefined
Src/Parse/yyConstraint.cpp:148:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:27:1: warning: "FdoToken_OVERLAPS" redefined
Src/Parse/yyConstraint.cpp:149:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:28:1: warning: "FdoToken_TOUCHES" redefined
Src/Parse/yyConstraint.cpp:150:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:29:1: warning: "FdoToken_WITHIN" redefined
Src/Parse/yyConstraint.cpp:151:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:30:1: warning: "FdoToken_RELATE" redefined
Src/Parse/yyConstraint.cpp:152:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:31:1: warning: "FdoToken_IDENTIFIER" redefined
Src/Parse/yyConstraint.cpp:153:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:32:1: warning: "FdoToken_PARAMETER" redefined
Src/Parse/yyConstraint.cpp:154:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:33:1: warning: "FdoToken_STRING" redefined
Src/Parse/yyConstraint.cpp:155:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:34:1: warning: "FdoToken_INTEGER" redefined
Src/Parse/yyConstraint.cpp:156:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:35:1: warning: "FdoToken_INT64" redefined
Src/Parse/yyConstraint.cpp:157:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:36:1: warning: "FdoToken_DOUBLE" redefined
Src/Parse/yyConstraint.cpp:158:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:37:1: warning: "FdoToken_DATETIME" redefined
Src/Parse/yyConstraint.cpp:159:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:38:1: warning: "FdoToken_BLOB" redefined
Src/Parse/yyConstraint.cpp:160:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:39:1: warning: "FdoToken_CLOB" redefined
Src/Parse/yyConstraint.cpp:161:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:40:1: warning: "FdoToken_Add" redefined
Src/Parse/yyConstraint.cpp:162:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:41:1: warning: "FdoToken_Subtract" redefined
Src/Parse/yyConstraint.cpp:163:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:42:1: warning: "FdoToken_Multiply" redefined
Src/Parse/yyConstraint.cpp:164:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:43:1: warning: "FdoToken_Divide" redefined
Src/Parse/yyConstraint.cpp:165:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:44:1: warning: "FdoToken_Negate" redefined
Src/Parse/yyConstraint.cpp:166:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:45:1: warning: "FdoToken_EQ" redefined
Src/Parse/yyConstraint.cpp:167:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:46:1: warning: "FdoToken_NE" redefined
Src/Parse/yyConstraint.cpp:168:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:47:1: warning: "FdoToken_GT" redefined
Src/Parse/yyConstraint.cpp:169:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:48:1: warning: "FdoToken_GE" redefined
Src/Parse/yyConstraint.cpp:170:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:49:1: warning: "FdoToken_LT" redefined
Src/Parse/yyConstraint.cpp:171:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:50:1: warning: "FdoToken_LE" redefined
Src/Parse/yyConstraint.cpp:172:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:51:1: warning: "FdoToken_LeftParenthesis"
redefined
Src/Parse/yyConstraint.cpp:173:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:52:1: warning: "FdoToken_RightParenthesis"
redefined
Src/Parse/yyConstraint.cpp:174:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:53:1: warning: "FdoToken_LeftSquareBrackets"
redefined
Src/Parse/yyConstraint.cpp:175:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:54:1: warning: "FdoToken_RightSquareBrackets"
redefined
Src/Parse/yyConstraint.cpp:176:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:55:1: warning: "FdoToken_Comma" redefined
Src/Parse/yyConstraint.cpp:177:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:56:1: warning: "FdoToken_Dot" redefined
Src/Parse/yyConstraint.cpp:178:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:57:1: warning: "FdoToken_Colon" redefined
Src/Parse/yyConstraint.cpp:179:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:58:1: warning: "FdoToken_AS" redefined
Src/Parse/yyConstraint.cpp:180:1: warning: this is the location of the
previous definition
./Inc/Parse/yyConstraint.h:59:1: warning: "FdoToken_BETWEEN" redefined
Src/Parse/yyConstraint.cpp:181:1: warning: this is the location of the
previous definition
Utilities/Common/Src/Parse/yyConstraint.y:73: error: using typedef-name
'FDO_CONSTRAINT_YYSTYPE' after 'union'
./Inc/Parse/yyConstraint.h:69: error: 'FDO_CONSTRAINT_YYSTYPE' has a
previous declaration here
Utilities/Common/Src/Parse/yyConstraint.y:73: error: 'union' tag used in
naming '<type error>'
Utilities/Common/Src/Parse/yyConstraint.y:54: error: invalid function
declaration
yyConstraint.cpp:240: error: declaration does not declare anything
yyConstraint.cpp:415: error: expected ';' before '->' token
yyConstraint.cpp:416: error: expected ';' before '->' token
yyConstraint.cpp:1222: error: expected ',' or '...' before '->' token
yyConstraint.cpp: In function 'void fdo_constraint_yydestruct(const char*,
int, FDO_CONSTRAINT_YYSTYPE*)':
yyConstraint.cpp:1231: error: 'union _FDO_CONSTRAINT_YYSTYPE' has no member
named 'fdo_constraint_yyvaluep'
yyConstraint.cpp: In function 'int fdo_constraint_yyparse()':
yyConstraint.cpp:1323: error: expected initializer before '->' token
yyConstraint.cpp:1324: error: expected initializer before '->' token
yyConstraint.cpp:1328: error: expected initializer before '->' token
yyConstraint.cpp:1334: error: expected initializer before '->' token
yyConstraint.cpp:1348: error: 'pParse' was not declared in this scope
yyConstraint.cpp:1416: error: 'union fdo_constraint_yyalloc' has no member
named 'pParse'
named 'pParse'
yyConstraint.cpp:1417: error: 'union fdo_constraint_yyalloc' has no member
named 'fdo_constraint_yyvs'
yyConstraint.cpp:1417: error: 'fdo_constraint_yyvs' was not declared in
this scope
./Inc/Parse/Parse.h:118: error: too few arguments to function 'FdoInt32
fdo_constraint_yylex(FdoCommonParse*)'
yyConstraint.cpp:1460: error: at this point in file
yyConstraint.cpp:2016: error: cannot convert 'const char*' to
'FdoCommonParse*' for argument '1' to 'FdoInt32
fdo_constraint_yyerror(FdoCommonParse*, char*)'
yyConstraint.cpp:2162: error: cannot convert 'const char*' to
make[1]: *** [yyConstraint.lo] Error 1
make[1]: Leaving directory `/usr/local/src/OpenSource_FDO/Utilities/Common'
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
redefined
previous definition
previous definition
previous definition
previous definition
previous definition
redefined
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
redefined
previous definition
redefined
previous definition
redefined
previous definition
redefined
previous definition
previous definition
previous definition
previous definition
previous definition
previous definition
declaration
named 'pParse'
named 'pParse'
this scope
yes
yes
yes
config.status: creating Inc/Makefile
config.status: creating Src/Makefile
config.status: creating Src/Message/Makefile
config.status: creating Src/ShpRead/Makefile
config.status: creating Src/ShpSpatialIndex/Makefile
config.status: creating Src/Overrides/Makefile
config.status: creating Src/Provider/Makefile
config.status: creating Src/UnitTest/Makefile
config.status: creating Docs/Makefile
config.status: creating Docs/doc_src/Makefile
config.status: creating Docs/doc_src/group_and_page_definitions/Makefile
config.status: creating Docs/doc_src/headers_and_footers/Makefile
Making all in Src
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src'
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src/Message'
Making all in ShpRead
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src/ShpRead'
make[2]: Nothing to be done for `all'.
Making all in ShpSpatialIndex
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src/ShpSpatialIndex'
Making all in Overrides
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src/Overrides'
Making all in Provider
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src/Provider'
Making all in UnitTest
`/usr/local/src/OpenSource_FDO/Providers/SHP/Src/UnitTest'
make[2]: *** No rule to make target
`/usr/local/src/OpenSource_FDO/Utilities/Common/libProvidersCommon.la',
needed by `UnitTest'. Stop.
Making install in ShpRead
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
Making install in ShpSpatialIndex
Making install in Overrides
Making install in Provider
Making install in UnitTest
yes
yes
yes
configure: error: The default ESRI ArcSDE SDK path DEFAULT is not a valid
directory. Please use the custom option
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
yes
yes
yes
configure: Building with default location of MySQL SDK files at
/usr/include/mysql
configure: Building with default location of ODBC SDK files at /usr
config.status: creating com/Makefile
config.status: creating Nls/Makefile
config.status: creating Src/Fdo/Makefile
config.status: creating Src/Fdo/Capability/Makefile
config.status: creating Src/Fdo/Connection/Makefile
config.status: creating Src/Fdo/Custom/Makefile
config.status: creating Src/Fdo/DataStore/Makefile
config.status: creating Src/Fdo/FeatureCommands/Makefile
config.status: creating Src/Fdo/Filter/Makefile
config.status: creating Src/Fdo/Lock/Makefile
config.status: creating Src/Fdo/Lt/Makefile
config.status: creating Src/Fdo/Other/Makefile
config.status: creating Src/Fdo/Pvc/Makefile
config.status: creating Src/Fdo/Schema/Makefile
config.status: creating Src/Fdo/SpatialContext/Makefile
config.status: creating Src/Gdbi/Makefile
config.status: creating Src/Geometry/Makefile
config.status: creating Src/Geometry/Fgf/Makefile
config.status: creating Src/LongTransactionManager/Makefile
config.status: creating Src/LockManager/Makefile
config.status: creating Src/MySQL/Makefile
config.status: creating Src/MySQL/Driver/Makefile
config.status: creating Src/MySQL/Fdo/Makefile
config.status: creating Src/MySQL/SchemaMgr/Makefile
config.status: creating Src/MySQL/SchemaMgr/Lp/Makefile
config.status: creating Src/MySQL/SchemaMgr/Ov/Makefile
config.status: creating Src/MySQL/SchemaMgr/Ph/Makefile
config.status: creating Src/MySQL/SchemaMgr/Ph/Rd/Makefile
config.status: creating Src/Rdbi/Makefile
config.status: creating Src/SchemaMgr/Makefile
config.status: creating Src/SchemaMgr/Lp/Makefile
config.status: creating Src/SchemaMgr/Ov/Makefile
config.status: creating Src/SchemaMgr/Ph/Makefile
config.status: creating Src/SchemaMgr/Ph/Cfg/Makefile
config.status: creating Src/SchemaMgr/Ph/Rd/Makefile
config.status: creating Src/UnitTest/Common/Makefile
config.status: creating Src/UnitTest/MySql/Makefile
config.status: creating Src/Util/Makefile
config.status: creating Src/ODBCDriver/Makefile
config.status: creating Src/ODBC/Makefile
config.status: creating Src/ODBC/Fdo/Makefile
config.status: creating Src/ODBC/SchemaMgr/Makefile
config.status: creating Src/ODBC/SchemaMgr/Lp/Makefile
config.status: creating Src/ODBC/SchemaMgr/Ov/Makefile
config.status: creating Src/ODBC/SchemaMgr/Ph/Makefile
config.status: creating Src/ODBC/SchemaMgr/Ph/Rd/Makefile
config.status: creating Src/UnitTest/Odbc/Makefile
config.status: creating Docs/doc_src/headers_and_footers/MySQL/Makefile
config.status: creating Docs/doc_src/headers_and_footers/ODBC/Makefile
Docs/doc_src/group_and_page_definitions/MySQL/Makefile
Docs/doc_src/group_and_page_definitions/ODBC/Makefile
Making all in Nls
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Nls'
Making all in Src
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src'
Making all in Fdo
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo'
Making all in Capability
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Capability'
make[3]: Nothing to be done for `all'.
Making all in Connection
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Connection'
Making all in Custom
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Custom'
Making all in DataStore
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/DataStore'
Making all in FeatureCommands
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/FeatureCommands'
Making all in Filter
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Filter'
Making all in Lock
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Lock'
Making all in Lt
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Lt'
Making all in Other
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Other'
Making all in Pvc
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Pvc'
Making all in Schema
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/Schema'
Making all in SpatialContext
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Fdo/SpatialContext'
make[3]: Nothing to be done for `all-am'.
Making all in Gdbi
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Gdbi'
Making all in LongTransactionManager
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/LongTransactionManager'
Making all in LockManager
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/LockManager'
Making all in MySQL
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL'
Making all in Driver
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/Driver'
Making all in Fdo
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/Fdo'
Making all in SchemaMgr
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/SchemaMgr'
Making all in Lp
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp'
Making all in Ov
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ov'
Making all in Ph
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph'
Making all in Rd
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd'
make[5]: Nothing to be done for `all'.
make[5]: Nothing to be done for `all-am'.
make[4]: Nothing to be done for `all-am'.
Making all in Rdbi
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/Rdbi'
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/SchemaMgr'
Making all in Lp
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/SchemaMgr/Lp'
Making all in Ov
`/usr/local/src/OpenSource_FDO/Providers/GenericRdbms/Src/SchemaMgr/Ov'
make[3]: *** No rule to make target
`/usr/local/src/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la', needed by
`libSchemaMgr_OV.la'. Stop.
Making install in Capability
make[4]: Nothing to be done for `install-exec-am'.
make[4]: Nothing to be done for `install-data-am'.
Making install in Connection
Making install in Custom
Making install in DataStore
Making install in FeatureCommands
Making install in Filter
Making install in Lock
Making install in Lt
Making install in Other
Making install in Pvc
Making install in Schema
Making install in SpatialContext
Making install in Gdbi
Making install in LongTransactionManager
Making install in LockManager
Making install in MySQL
Making install in Driver
Making install in SchemaMgr
Making install in Lp
Making install in Ph
Making install in Rd
make[6]: Entering directory
make[6]: Nothing to be done for `install-exec-am'.
make[6]: Nothing to be done for `install-data-am'.
make[6]: Leaving directory
Making install in Rdbi
yes
yes
yes
configure: Building with default location of thirdparty GDAL files at
/usr/local/src/OpenSource_FDO/Thirdparty/gdal
Making all in Src
`/usr/local/src/OpenSource_FDO/Providers/GDAL/Src'
`/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/Message'
`/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/Overrides'
`/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/Provider'
`/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
On Tue, 29 Jul 2008 19:16:01 -0700, Jack Lee <jack.lee at autodesk.com> wrote:
> Hi,
> Did the build_linux.sh script build
> /usr/local/src/OpenSource_FDO/Utilities/Common?
> ________________________________________
> [fdo-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> [zac.spitzer at gmail.com]
> Sent: Tuesday, July 29, 2008 9:47 PM
> Subject: Re: [fdo-users] FDO doesn't compile on Debian Linux
> is it the bash dash sh problem ?
> On Wed, Jul 30, 2008 at 11:46 AM, <mike at malagatech.com> wrote:
>> The second "O" in Source is a typo; the path being used is correct.
>> Mike
>> On Tue, 29 Jul 2008 15:36:30 -0700, Jack Lee <jack.lee at autodesk.com>
> wrote:
>>> Hi,
>>> Is /usr/local/src/OpenSOurce_FDO the correct directory? Notice the
> second
>>> capital O in OpenSOurce_FDO?
>>> '/usr/local/src/OpenSOurce_FDO/Utilities/Common/libProviderCommon.la',
>>> needed by 'UnitTest'. Stop.
>>> Sent: Tuesday, July 29, 2008 5:42 PM
>>> To: fdo-users at lists.osgeo.org
>>> Subject: [fdo-users] FDO doesn't compile on Debian Linux
>>> I have downloaded version 3.3.1 of FDO to my Debian Linux system. I'm
>>> running the current stable distribution of Debian with the latest
>>> updates.
>>> I believe I have installed of the required Debian packages to be able
> to
>>> build and install FDO. In addition to the base FDO source I also
>>> downloaded the following providers: ArcSDE, GDAL, GenericRdbms, SHP. I
>>> am
>>> able to run "source setenvironment.sh" without an error. I am able to
>>> run
>>> "./build_thirdparty.sh" without an error. When I try to run
>>> "./build_linux.sh" or "./build_linux.sh --c release --a buildinstall
> --m
>>> configure --w all" the process works for a while and then dies with the
>>> error:
>>> '/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
>>> '/usr/local/src/OpenSource_FDO/Providers/GDAL/Src'
>>> Any help would be appreciated,
>>> Thank you,
>>> Mike Juneau
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
More information about the fdo-users
