[fdo-users] RE: Property2ColNameChar
Dan Stoica
dan.stoica at autodesk.com
Wed Jun 11 11:50:51 EDT 2008
> we are missing "stanadard" index access to properties and than application can decide which one to use.
Even so, the provider has to keep an internal mapping because the index of the property doesn't necessary match the index of the corresponding column (e.g. RevisionNumber column).
Besides, doing everything under the hood has another advantage: it saves the conversion from wchar to char (usually needed when going from logical to physical) by caching the char value as well.
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Wednesday, June 11, 2008 11:15 AM
To: FDO Users Mail List
Subject: [fdo-users] RE: Property2ColNameChar
I have looked at the code of Property2ColNameChar and few questions pop
up.
I believe when I was developing King.Oracle I was posting that we would
need to have index access to properties, simillar as database client
APIs have. I am not sure but I would be suprised if other database
access software have implemented such mechanisems on data access level.
To me , It looks like that we are missing "stanadard" index access to
Haris
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Wednesday, June 11, 2008 4:23 PM
Subject: RE: [fdo-users] PostGIS FDO Provider performance issues
My bet is that "something else" is the look up for the property in the
logical/physical collections of properties.
E.g. for 20 properties in the class the provider will do aprox.
2,000,000 wide string comparisons for 200,000 rows.
Actually it is 4 million because of IsNull() calls. This is the
performance killer.
The problem has been solved for rdbms providers by caching the
properties in the order they are fetched (at the first fetch). So the
property will be found either in the same position (after a IsNull) or
in the next slot. This is equivalent to fetching a property by index
rather by name.
The implementation is in GenericRdbms:
FdoRdbmsFeatureReader::Property2ColNameChar()
Hope this helps,
Dan.
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, June 11, 2008 3:03 AM
Subject: Re: [fdo-users] PostGIS FDO Provider performance issues
I would agree it's too much overhead, as this happening with Oracle as
well ( anyone else seen
this happen with another db?) perhaps there is something else in play.
How many rows are fetched by the client? Fetching one row at a time is
slower than returning blocks of 100 rows..
Using mapguide, it's always the mapguide process (ie FDO) and not the
database which is showing the high cpu
z
On Wed, Jun 11, 2008 at 4:56 PM, Carl Jokl <carl.jokl at keynetix.com>
wrote:
> It is true that there is extra overhead in performing the conversion
or going
> through FDO but I think it is fair to say that having PostGIS 16 to 20
times
> slower on the same data is more of a performance hit than would have
been
> expected.
http://www.nabble.com/PostGIS-FDO-Provider-performance-issues-tp17756475
p17771210.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fdo-users
