[fdo-users] RE: Property2ColNameChar
Traian Stanev
traian.stanev at autodesk.com
Wed Jun 11 12:54:54 EDT 2008
The FDO feature reader API requires you to pass a string property name. Do you agree?
Somewhere this string needs to be converted to an integer somehow, in order to access a column by index. Do you agree?
I don't see how you can keep arguing those two simple facts.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Dan Stoica
> Sent: Wednesday, June 11, 2008 12:50 PM
> To: FDO Users Mail List
> Subject: RE: [fdo-users] RE: Property2ColNameChar
> " This happens every time you need to access the value of any column
> via the FDO feature reader."
> No. The internal caching is based on the assumption that the properties
> are fetched in the same order. So the mapping occurs only once, at the
> 1st ReadNext().
> Dan.
> bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Wednesday, June 11, 2008 12:19 PM
> > And how would it help in the most common use case, "Select *" ?
> OK suppose you do a "select *".
> Then you get a feature reader back and you need to read property
> values, for example for geometry. You call
> Blah = reader->GetGeometry(L"GEOM");
> Internally the provider has to map the L"GEOM" to a column index. This
> happens every time you need to access the value of any column via the
> FDO feature reader.
> Traian
> > Sent: Wednesday, June 11, 2008 12:15 PM
> > Yes, but it also true that the providers already enhanced will be
> > penalized without a real benefit because they have to implement "Get
> by
> > index" :-)
> > Dan.
> > Sent: Wednesday, June 11, 2008 11:53 AM
> > True, but this only applies to some providers. Other providers, which
> > can deterministically map property name to index, are penalized
> > unnecessarily.
> > Traian
> > > Sent: Wednesday, June 11, 2008 11:51 AM
> > > > we are missing "stanadard" index access to properties and than
> > > application can decide which one to use.
> > > Even so, the provider has to keep an internal mapping because the
> > index
> > > of the property doesn't necessary match the index of the
> > corresponding
> > > column (e.g. RevisionNumber column).
> > > Besides, doing everything under the hood has another advantage: it
> > > saves the conversion from wchar to char (usually needed when going
> > from
> > > logical to physical) by caching the char value as well.
> > > Dan.
> > > bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> > > Sent: Wednesday, June 11, 2008 11:15 AM
> > > Subject: [fdo-users] RE: Property2ColNameChar
> > > I have looked at the code of Property2ColNameChar and few questions
> > pop
> > > up.
> > > I believe when I was developing King.Oracle I was posting that we
> > would
> > > need to have index access to properties, simillar as database
> client
> > > APIs have. I am not sure but I would be suprised if other database
> > > access software have implemented such mechanisems on data access
> > level.
> > > To me , It looks like that we are missing "stanadard" index access
> to
> > > properties and than application can decide which one to use.
> > > Haris
> > > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
> > > Sent: Wednesday, June 11, 2008 4:23 PM
> > > Subject: RE: [fdo-users] PostGIS FDO Provider performance issues
> > > My bet is that "something else" is the look up for the property in
> > the
> > > logical/physical collections of properties.
> > > E.g. for 20 properties in the class the provider will do aprox.
> > > 2,000,000 wide string comparisons for 200,000 rows.
> > > Actually it is 4 million because of IsNull() calls. This is the
> > > performance killer.
> > > The problem has been solved for rdbms providers by caching the
> > > properties in the order they are fetched (at the first fetch). So
> the
> > > property will be found either in the same position (after a IsNull)
> > or
> > > in the next slot. This is equivalent to fetching a property by
> index
> > > rather by name.
> > > The implementation is in GenericRdbms:
> > > FdoRdbmsFeatureReader::Property2ColNameChar()
> > > Hope this helps,
> > > Dan.
> > > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> > > Sent: Wednesday, June 11, 2008 3:03 AM
> > > Subject: Re: [fdo-users] PostGIS FDO Provider performance issues
> > > I would agree it's too much overhead, as this happening with Oracle
> > as
> > > well ( anyone else seen
> > > this happen with another db?) perhaps there is something else in
> > play.
> > > How many rows are fetched by the client? Fetching one row at a time
> > is
> > > slower than returning blocks of 100 rows..
> > > Using mapguide, it's always the mapguide process (ie FDO) and not
> the
> > > database which is showing the high cpu
> > > z
> > > On Wed, Jun 11, 2008 at 4:56 PM, Carl Jokl <carl.jokl at keynetix.com>
> > > wrote:
> > > > It is true that there is extra overhead in performing the
> > conversion
> > > or going
> > > > through FDO but I think it is fair to say that having PostGIS 16
> to
> > > 20
> > > times
> > > > slower on the same data is more of a performance hit than would
> > have
> > > been
> > > > expected.
> > > > View this message in context:
> > > http://www.nabble.com/PostGIS-FDO-Provider-performance-issues-
> > > tp17756475
> > > p17771210.html
> > > > Sent from the FDO Users mailing list archive at Nabble.com.
> > > > _______________________________________________
> > > > fdo-users mailing list
> > > > fdo-users at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/fdo-users
> > > Zac Spitzer -
> > > http://zacster.blogspot.com (My Blog)
> > > +61 405 847 168
More information about the fdo-users
