[fdo-users] fdo 3.3
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Thu Mar 6 09:10:13 EST 2008
You may want to try:
iconnection.set_ConnectionString ("DefaultFileLocation=roads.shp"); // here add your connection string with path to your SHP file
FdoConnectionState state = iconnection.Open (); // Open the connection
In order to open a SHP connection you need to set the connection string and call Open function.
Romy.
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jani Prakshep S/O BharatB [prakshep_b_jani at yahoo.com]
Sent: Thursday, March 06, 2008 9:01 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] fdo 3.3
i cou't basic connection establish of fdoshp provider.
pl. give me some example with code
i written my program this way,
package WindowsApplication1;
import System.Collections.Generic.*;
import System.Windows.Forms.*;
import OSGeo.FDO.ClientServices.*;
import OSGeo.FDO.Commands.*;
import OSGeo.FDO.Common.*;
import OSGeo.FDO.Connections.*;
import OSGeo.FDO.*;
import OSGeo.FDO.Connections.IConnectionImp;
import OSGeo.FDO.Providers.SHP.Override.*;
* Summary description for Program
public class Program
public static IConnection fdoconnection;
public static IProviderRegistry providers_registry;
public static ProviderCollection providercoll;
public static Provider provider;
public static IConnectionManager fdoconnectionmgr;
public static IConnection iconnection;
//public static IConnectionImp icon = new IConnectionImp();
Program()
System.out.println("Connection Services Started...... ");
providers_registry = FeatureAccessManager.GetProviderRegistry();
providercoll = providers_registry.GetProviders();
int No_of_registerd_provider = providercoll.get_Count();
for (int i = 0; i < No_of_registerd_provider; i++)
provider = providercoll.get_RealTypeItem(i);
String name = provider.get_Name();
if ((name.compareTo("OSGeo.SHP.3.2")) == 0)
fdoconnectionmgr = FeatureAccessManager.GetConnectionManager();
iconnection = fdoconnectionmgr.CreateConnection(name);
ConnectionState state = iconnection.get_ConnectionState();
IConnectionInfo info = iconnection.get_ConnectionInfo();
//ConnectionState state = icon.get_ConnectionState();
break;
//String pro_name = provider.get_DisplayName();
* The main entry point for the application.
/** @attribute System.STAThread() */
public static void main(String[] args)
Program p = new Program();
above code give true information but connection state is shows CLOSE.
that's why pl. give me some code for any provider. then i go ahead otherwise
i try and try.......but do not get result....
View this message in context: http://www.nabble.com/fdo-3.3-tp15873138s18162p15873138.html
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
