[fdo-users] MPolygon <-> FDO
djonio
djonio at miami-airport.com
Thu Mar 6 09:46:10 EST 2008
Howdy,
I am trying to “FDOisize” a Map3d MPolygon object. The linear case is
trivial. However, my users wish to use arcs. At least to me, this is NOT
trivial. The following works in cases where the CircularArcSegment is not
the first segment drawn in the MPolygon. When it is drawn first the failure
is in the IRing ring = fgf.CreateRing(CurveSegmentColl); statement(says the
ring is not closed.) Also, if a create a MPolygon from two(2) arcs … it
fails.
I am open to any and all suggestions and will send the entire project if
that helps.
dennis
public static IGeometry GeometryInterfaceFromMPolygon(MPolygon
mpoly)
IGeometry rtn_IGeometry = null;
IRing irExternal = null;
RingCollection RingColl = new RingCollection();
CurveSegmentCollection CurveSegmentColl = new
CurveSegmentCollection();
FgfGeometryFactory fgf = new FgfGeometryFactory();
if (IsItACurvePolygon(mpoly) == true)
ICircularArcSegment aCircArcSeg;
ILineStringSegment aLineStringSeg;
DirectPositionCollection DirectPositionColl = new
DirectPositionCollection();
int loops = mpoly.NumMPolygonLoops;
for (int i = 0; i < loops; i++)
MPolygonLoop mPolygonLoop = mpoly.GetMPolygonLoopAt(i);
for (int j = 0; j < mPolygonLoop.Count - 1; j++)
aCircArcSeg = null;
aLineStringSeg = null;
BulgeVertex bv = mPolygonLoop[j];
double Vbulge = bv.Bulge;
if (Vbulge != 0.0)
CircularArc2d ca2d = new
CircularArc2d(bv.Vertex, mPolygonLoop[j + 1].Vertex, bv.Bulge, false);
DirectPositionImpl dpi_start = new
DirectPositionImpl(ca2d.StartPoint.X, ca2d.StartPoint.Y);
DirectPositionImpl dpi_end = new
DirectPositionImpl(ca2d.EndPoint.X, ca2d.EndPoint.Y);
Point2d midpoint = ca2d.EvaluatePoint(0.5);
DirectPositionImpl dpi_center = new
DirectPositionImpl(midpoint.X, midpoint.Y);
aCircArcSeg =
fgf.CreateCircularArcSegment(dpi_start, dpi_center, dpi_end);
else
DirectPositionColl.Clear();
DirectPositionImpl seg_s = new
DirectPositionImpl(bv.Vertex.X, bv.Vertex.Y);
DirectPositionColl.Add(seg_s);
DirectPositionImpl seg_e = new
DirectPositionImpl(mPolygonLoop[j + 1].Vertex.X, mPolygonLoop[j +
1].Vertex.Y);
DirectPositionColl.Add(seg_e);
aLineStringSeg =
fgf.CreateLineStringSegment(DirectPositionColl);
if (aLineStringSeg != null)
CurveSegmentColl.Add(aLineStringSeg);
else
CurveSegmentColl.Add(aCircArcSeg);
} // for vertex count
if (i == 0)
irExternal = ring;
else
RingColl.Add(ring);
}// for each loop in the mpolygon
rtn_IGeometry = fgf.CreateCurvePolygon(irExternal,
RingColl);
else
double[] Ordinates;
int OrdinateCount = 0;
int OrdinateIndex = 0;
ILinearRing iExternalLinearRing = null;
ILinearRing iLinearRingInner = null;
LinearRingCollection LinearRingColl = new
LinearRingCollection();
// the count of 2d points
int verts = mPolygonLoop.Count;
// the count of ordinates
OrdinateCount = verts * 2;
Ordinates = new double[OrdinateCount];
OrdinateIndex = 0;
foreach (BulgeVertex bv in mPolygonLoop)
Point2d V2dp = bv.Vertex;
Ordinates[OrdinateIndex++] = V2dp.X;
Ordinates[OrdinateIndex++] = V2dp.Y;
if (i == 0)
iExternalLinearRing = fgf.CreateLinearRing(0,
OrdinateCount, Ordinates);
else
iLinearRingInner = fgf.CreateLinearRing(0,
LinearRingColl.Add(iLinearRingInner);
rtn_IGeometry = fgf.CreatePolygon(iExternalLinearRing,
LinearRingColl);
return rtn_IGeometry;
View this message in context: http://www.nabble.com/MPolygon-%3C-%3E-FDO-tp15873165s18162p15873165.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
