[fdo-users] MPolygon <-> FDO
Gavin Cramer
gavin.cramer at autodesk.com
Thu Mar 6 13:37:17 EST 2008
DirectPositionImpl does not do any rounding or conversion. It just makes binary copies of ordinates.
Your printouts of MPolygon ordinates have 15 decimal digits of precision (13 or 14 after the decimal point), while the DirectPositionImpl printouts have two more digits. The only differences that I can see are due to rounding for printing. What happens if the same length is used for both?
Gavin
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jonio, Dennis (Aviation)
Sent: Thursday, March 06, 2008 1:16 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] MPolygon <-> FDO
Gavin,
It appears, on the surface at least, that DirectPositionImpl is not
returning the same values that it is being handed. Since in my test
case, that I include below, uses a CircularArc2d object I show that
also. That object hands back what it is passed so I am fairly sure that
that is not the issue.
It looks to me that there are rounding and precision differences. But at
least in this case it looks to me like the MPolygon vertices were all
correctly formed.
DirectPositionImpl? Any additional thoughts?
The Points from the Mpolygon
- p {Dimensions:[4]}
Autodesk.AutoCAD.Geometry.Point2d[]
+ [0] {(61.9192385091388,10.2621902206345)}
+ [1] {(55.2181323514077,1.46976527536452)}
+ [2] {(70.4772774942939,4.8576720597566)}
+ [3] {(61.9192385091388,10.2621902206345)}
Iteration:(0)
- seg_s {OSGeo.FDO.Geometry.DirectPositionImpl}
+ base {OSGeo.FDO.Geometry.DirectPositionImpl}
OSGeo.FDO.Runtime.Disposable {OSGeo.FDO.Geometry.DirectPositionImpl}
Dimensionality 0 int
M NaN double
X 61.919238509138836 double
Y 10.262190220634466 double
Z NaN double
the MPolygon says: 61.9192385091388,10.2621902206345
- seg_e {OSGeo.FDO.Geometry.DirectPositionImpl}
M NaN double
X 55.218132351407746 double
Y 1.4697652753645229 double
Z NaN double
the MPolygon says: 55.2181323514077,1.46976527536452
Iteration:(1)
M NaN double
Z NaN double
M NaN double
X 70.4772774942939 double
Y 4.8576720597565952 double
Z NaN double
the Mpolygon says: 70.4772774942939,4.8576720597566
Iteration:(2)
- dpi_start {OSGeo.FDO.Geometry.DirectPositionImpl}
M NaN double
Z NaN double
- dpi_end {OSGeo.FDO.Geometry.DirectPositionImpl}
M NaN double
X 61.919238509138843 double
Y 10.26219022063446 double
Z NaN double
the Mpolygon says: 61.9192385091388,10.2621902206345
The CircularArc2d object
- ca2d {Autodesk.AutoCAD.Geometry.CircularArc2d}
+ base {Autodesk.AutoCAD.Geometry.CircularArc2d}
Autodesk.AutoCAD.Geometry.Curve2d
+ Center {(61.9192385091388,0.784116063691346)}
EndAngle 1.1265391183658797 double
+ EndPoint {(61.9192385091388,10.2621902206345)}
IsClockWise false bool
Radius 9.4780741569431157 double
+ ReferenceVector {(0.902930156848995,0.429787310018163)}
Autodesk.AutoCAD.Geometry.Vector2d
StartAngle 0.0 double
+ StartPoint {(70.4772774942939,4.8576720597566)}
the Mpolygon says:START = 70.4772774942939,4.8576720597566
the Mpolygon says:END = 61.9192385091388,10.2621902206345
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
