[fdo-users] MPolygon <-> FDO
Jonio, Dennis (Aviation)
DJonio at miami-airport.com
Fri Mar 7 07:11:44 EST 2008
Gavin,
I have gone back and attempted to "coerce the starting and ending
positions" I am not sure if my implementation is what you had in mind
but it is my interpretation. I still does not work with two(2) arcs and
again the case of a starting arc and any number of vertices.
I have been working with Dongjin Xing - Developer Technical Services -
Case # 1239296 and he is getting similar results.
We have a conference call this AM and maybe we will be able to find a
solution.
dennis
public static IGeometry GeometryInterfaceFromMPolygon(MPolygon
mpoly)
IGeometry rtn_IGeometry = null;
IRing irExternal = null;
RingCollection RingColl = new RingCollection();
CurveSegmentCollection CurveSegmentColl = new
CurveSegmentCollection();
FgfGeometryFactory fgf = new FgfGeometryFactory();
if (IsItACurvePolygon(mpoly) == true)
ICircularArcSegment aCircArcSeg;
ILineStringSegment aLineStringSeg;
DirectPositionCollection DirectPositionColl = new
DirectPositionCollection();
int loops = mpoly.NumMPolygonLoops;
for (int i = 0; i < loops; i++)
MPolygonLoop mPolygonLoop =
mpoly.GetMPolygonLoopAt(i);
Point2d[] pts = new Point2d[mPolygonLoop.Count];
double[] blgs = new double[mPolygonLoop.Count];
int z = 0;
for (; z < mPolygonLoop.Count; z++)
if (z == mPolygonLoop.Count - 1)
pts[z] = mPolygonLoop[0].Vertex;
else
pts[z] = mPolygonLoop[z].Vertex;
blgs[z] = mPolygonLoop[z].Bulge;
for (int j = 0; j < mPolygonLoop.Count - 1; j++)
aCircArcSeg = null;
aLineStringSeg = null;
double theBulge = blgs[j];
if (theBulge != 0.0)
CircularArc2d ca2d = new
CircularArc2d(pts[j], pts[j + 1], theBulge, false);
DirectPositionImpl dpi_start = new
DirectPositionImpl(ca2d.StartPoint.X, ca2d.StartPoint.Y);
DirectPositionImpl dpi_end = new
DirectPositionImpl(ca2d.EndPoint.X, ca2d.EndPoint.Y);
Point2d midpoint = ca2d.EvaluatePoint(0.5);
DirectPositionImpl dpi_center = new
DirectPositionImpl(midpoint.X, midpoint.Y);
aCircArcSeg =
fgf.CreateCircularArcSegment(dpi_start, dpi_center, dpi_end);
else
DirectPositionColl.Clear();
DirectPositionImpl seg_s = new
DirectPositionImpl(pts[j].X, pts[j].Y);
DirectPositionColl.Add(seg_s);
DirectPositionImpl seg_e = new
DirectPositionImpl(pts[j + 1].X, pts[j + 1].Y);
DirectPositionColl.Add(seg_e);
aLineStringSeg =
fgf.CreateLineStringSegment(DirectPositionColl);
if (aLineStringSeg != null)
CurveSegmentColl.Add(aLineStringSeg);
else
CurveSegmentColl.Add(aCircArcSeg);
} // for vertex count
IRing ring = fgf.CreateRing(CurveSegmentColl);
if (i == 0)
irExternal = ring;
else
RingColl.Add(ring);
}// for each loop in the mpolygon
rtn_IGeometry = fgf.CreateCurvePolygon(irExternal,
RingColl);
else
double[] Ordinates;
int OrdinateCount = 0;
int OrdinateIndex = 0;
ILinearRing iExternalLinearRing = null;
ILinearRing iLinearRingInner = null;
LinearRingCollection LinearRingColl = new
LinearRingCollection();
// the count of 2d points
int verts = mPolygonLoop.Count;
// the count of ordinates
OrdinateCount = verts * 2;
Ordinates = new double[OrdinateCount];
OrdinateIndex = 0;
foreach (BulgeVertex bv in mPolygonLoop)
Point2d V2dp = bv.Vertex;
Ordinates[OrdinateIndex++] = V2dp.X;
Ordinates[OrdinateIndex++] = V2dp.Y;
if (i == 0)
iExternalLinearRing = fgf.CreateLinearRing(0,
OrdinateCount, Ordinates);
else
iLinearRingInner = fgf.CreateLinearRing(0,
LinearRingColl.Add(iLinearRingInner);
rtn_IGeometry = fgf.CreatePolygon(iExternalLinearRing,
LinearRingColl);
return rtn_IGeometry;
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Gavin Cramer
Sent: Thursday, March 06, 2008 7:17 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] MPolygon <-> FDO
Hello again, Dennis. That comparison of Point2D objects may call code
that includes internal distance calculations and comparisons with
tolerances. The definitive test would be to check the X and Y ordinates
directly.
Gavin
More information about the fdo-users
