[fdo-users] MPolygon <-> FDO
Brad Nesom
kidsmake6 at msn.com
Fri Mar 7 11:58:40 EST 2008
I am way out of my league here but in the gui you need a direction to keep
the arc from inverting or spinning the wrong way. Is that in play here?
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jonio, Dennis
(Aviation)
Sent: Thursday, March 06, 2008 2:17 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] MPolygon <-> FDO
Gavin,
For every test case I have done this:
Point2d[] p = new Point2d[mPolygonLoop.Count];
for (int z = 0; z < mPolygonLoop.Count; z++)
p[z] = mPolygonLoop[z].Vertex;
if (p[0] != p[mPolygonLoop.Count - 1])
Breakpoint HERE---> int ifin_i_get_here_things_are_bad = 1;
In all cases the MPolygon vertices passed this test.
Again things go bad when an arc is the first segment drawn and obviously
if I construct the Mpolygon from all arcs.
In all cases when the MPolygon begins with a LineSegment and I add arcs
later it works.
Am I missing something obvious?
dennis
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Gavin Cramer
Sent: Thursday, March 06, 2008 2:11 PM
Ah. Unfortunately, such a printout is not a reliable way of testing
whether two floating-point numbers are identical. Checking
programmatically would be required here.
Gavin
(Aviation)
Sent: Thursday, March 06, 2008 1:46 PM
Gavin,
I just copied these values from the locals from the VS 2005 debug
display. I did no formatting.
dennis
Sent: Thursday, March 06, 2008 1:37 PM
DirectPositionImpl does not do any rounding or conversion. It just
makes binary copies of ordinates.
Your printouts of MPolygon ordinates have 15 decimal digits of precision
(13 or 14 after the decimal point), while the DirectPositionImpl
printouts have two more digits. The only differences that I can see are
due to rounding for printing. What happens if the same length is used
for both?
Gavin
(Aviation)
Sent: Thursday, March 06, 2008 1:16 PM
Gavin,
It appears, on the surface at least, that DirectPositionImpl is not
returning the same values that it is being handed. Since in my test
case, that I include below, uses a CircularArc2d object I show that
also. That object hands back what it is passed so I am fairly sure that
that is not the issue.
It looks to me that there are rounding and precision differences. But at
least in this case it looks to me like the MPolygon vertices were all
correctly formed.
DirectPositionImpl? Any additional thoughts?
The Points from the Mpolygon
- p {Dimensions:[4]}
Autodesk.AutoCAD.Geometry.Point2d[]
+ [0] {(61.9192385091388,10.2621902206345)}
+ [1] {(55.2181323514077,1.46976527536452)}
+ [2] {(70.4772774942939,4.8576720597566)}
+ [3] {(61.9192385091388,10.2621902206345)}
Iteration:(0)
- seg_s {OSGeo.FDO.Geometry.DirectPositionImpl}
+ base {OSGeo.FDO.Geometry.DirectPositionImpl}
OSGeo.FDO.Runtime.Disposable {OSGeo.FDO.Geometry.DirectPositionImpl}
Dimensionality 0 int
M NaN double
X 61.919238509138836 double
Y 10.262190220634466 double
Z NaN double
the MPolygon says: 61.9192385091388,10.2621902206345
- seg_e {OSGeo.FDO.Geometry.DirectPositionImpl}
M NaN double
X 55.218132351407746 double
Y 1.4697652753645229 double
Z NaN double
the MPolygon says: 55.2181323514077,1.46976527536452
Iteration:(1)
M NaN double
Z NaN double
M NaN double
X 70.4772774942939 double
Y 4.8576720597565952 double
Z NaN double
the Mpolygon says: 70.4772774942939,4.8576720597566
Iteration:(2)
- dpi_start {OSGeo.FDO.Geometry.DirectPositionImpl}
M NaN double
Z NaN double
- dpi_end {OSGeo.FDO.Geometry.DirectPositionImpl}
M NaN double
X 61.919238509138843 double
Y 10.26219022063446 double
Z NaN double
the Mpolygon says: 61.9192385091388,10.2621902206345
The CircularArc2d object
- ca2d {Autodesk.AutoCAD.Geometry.CircularArc2d}
+ base {Autodesk.AutoCAD.Geometry.CircularArc2d}
Autodesk.AutoCAD.Geometry.Curve2d
+ Center {(61.9192385091388,0.784116063691346)}
EndAngle 1.1265391183658797 double
+ EndPoint {(61.9192385091388,10.2621902206345)}
IsClockWise false bool
Radius 9.4780741569431157 double
+ ReferenceVector {(0.902930156848995,0.429787310018163)}
Autodesk.AutoCAD.Geometry.Vector2d
StartAngle 0.0 double
+ StartPoint {(70.4772774942939,4.8576720597566)}
the Mpolygon says:START = 70.4772774942939,4.8576720597566
the Mpolygon says:END = 61.9192385091388,10.2621902206345
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
E-mails are automatically scanned for viruses using McAfee.
More information about the fdo-users
