[fdo-users] .net Wrapper quirks
Clayton Hotson
clayton.hotson at autodesk.com
Fri Mar 28 05:33:37 EDT 2008
Thanks for putting this together, Maksim.
Regarding the use of the GC methods, I'm not certain these are what the FDO
guys had in mind to use (though it may actually workaround the problem, I'm
not sure) as there seems to be a clear disposal pattern in use with these
wrappers given that FDO is unmanaged underneath. Since the problem exhibits
itself with large datasets, we may also run out of memory if we keep
everything alive :-).
2c.
Clayton
Maksim Sestic wrote:
> Hi Greg,
> Here it is:
> http://trac.osgeo.org/fdo/ticket/284 http://trac.osgeo.org/fdo/ticket/284
> Regards,
> Maksim Sestic
> gregboone wrote:
>> Can you jot down in bullet point form the use case? Can you log a ticket
>> in Trac and attach any relevant data set?
>> Thanks,
>> Greg
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> Sent: Thursday, March 27, 2008 6:33 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] .net Wrapper quirks
>> I was "trusting" the managed API to do its thing (not unreasonable to
>> ask). I
>> do not know enough about native - managed interop in .net to know how to
>> properly utilise System.GC, could you perhaps enlighten me? ;-)
>> - Jackie
>> djonio wrote:
>>> Howdy,
>>> I am not familiar with this issue but I do find it very interesting.
>>> Have any of you used any of the System.GC methods( i.e.
>>> System.GC.KeepAlive method, System.GC.Collect method) during your
>>> process'? I wonder if they would have effect?
>>> Br,
>>> dennis
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> View this message in context:
>> http://www.nabble.com/.net-Wrapper-quirks-tp16318694s18162p16339508.html
>> Sent from the fdo-users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/.net-Wrapper-quirks-tp16318694s18162p16348709.html
More information about the fdo-users
