[fdo-users] Error: An exception occurred in FDO
component.CLNT_8_UNABLE_TO_LOAD_LIBRARY
AmilkarQuintero
amilkar.quintero at gmail.com
Fri Mar 28 15:17:53 EDT 2008
Andy
The entry in the providers.xml file has the provider i am invoking
<FeatureProvider>
<Name>Autodesk.Oracle.3.2</Name>
<DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
<Description>Read/write access to feature data in an Oracle-based data
store
. Supports spatial indexing, long transactions, and persistent
locking.</Descrip
tion>
<IsManaged>False</IsManaged>
<Version>3.2.2.0</Version>
<FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoRdbms.so</LibraryPath>
</FeatureProvider>
and the .so file is there too
libFdoRdbms.so
the LD_LIBRARY_PATH points to every lib path in the server
/usr/lib/oracle:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/serv
er/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideent
erprise2008/webserverextensions/lib:/opt/Autodesk/mapguideenterprise2008/webserv
erextensions/apache2/lib
What could have been wrong with the installation
Thanks
Amilkar
On Fri, Mar 28, 2008 at 11:49 AM, Andy Morsell <amorsell at spatialgis.com>
wrote:
> This error generally means that the particular FDO provider that is being
> referenced by a layer definition is not installed on the server. Take a
> look in your /usr/local/fdo-3.3.0/lib directory at the providers.xmlfile. In that file, find the provider entry for the provider you are trying
> to use, look at the LibraryPath and see if the .so file that is referenced
> exists in that directory. If not, your initial FDO compilation did not
> create that provider and you will have to trouble-shoot your FDO configure /
> make process to see if you are missing any environment variables, library
> dependencies, etc.
> This page has information that might be helpful:
> http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html.
> Also, be sure to look in your FDO source folder (OpenSource_FDO) for the
> OpenSourceBuild__README.txt file which has important information regarding
> building FDO with specific provider support.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *AmilkarQuintero
> *Sent:* Friday, March 28, 2008 8:34 AM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] Error: An exception occurred in FDO
> Hi, the following error is generated to the Error.Log file in my installation in Linux RH 4 ES. Has anyone solved this?
> *<2008-03-28T10:20:14> Administrator
> Error: An exception occurred in FDO component.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file FeatureServiceHandler.cpp
> - MgOpTestFeatureSourceConnection.Execute line 103 file OpTestFeatureSourceConnection.cpp
> - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp An exception occurred in FDO component.
> Thanks in advance
> here I send some data about my installation
> - The mapserver is Autodesk Mapguide 2008 Enterprise for Linux
> - Linux lucas.siicar.com 2.6.9-67.0.7.ELsmp #1 SMP Wed Feb 27
> 04:47:23 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> - The Oracle Instant Client installation
> - /usr/lib/oracle/10.2.0.3/client64/lib
> [root at lucas lib]# ls
> libclntsh.so.10.1 libnnz10.so libocci.so.10.1 libociei.so
> libocijdbc10.so ojdbc14.jar
> In another server we have the Oracle Database with the Spatial Tables we
> are trying to access
> - The Oracle Server, Oracle RDBMS 10g Release 2
> - Linux juan.siicar.com 2.6.18-53.1.14.el5 #1 SMP Tue Feb 19
> 07:18:46 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> - Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
> - PL/SQL Release 10.2.0.1.0 - Production
> - CORE 10.2.0.1.0 Production
> - TNS for Linux: Version 10.2.0.1.0 - Production
> - NLSRTL Version 10.2.0.1.0 - Production
> Amilkar Quintero G.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080328/6c13eb1d/attachment-0001.html
More information about the fdo-users
