[fdo-users] Error: An exception occurred
	in	FDOcomponent.CLNT_8_UNABLE_TO_LOAD_LIBRARY
    larry white
    larz at neomatix.ca
    Fri Mar 28 16:01:55 EDT 2008
Amilkar,
A while back, I did some testing with oracle and found that I had to add
some environment variables and modify the LD_LIBRARY_PATH variable in a
some files so that the oracle client libraries could be used by fdo.
file: $path_to_mapguide/webserverextensions/apache2/conf/mapguide.conf
ORACLE_HOME and TNS_ADMIN variables will need to be added.
Plus, you need to add $ORACLE/lib to LD_LIBRARY_PATH variable.
SetEnv ORACLE_HOME "/u01/app/oracle/product/10.2.0/db_1/"
SetEnv TNS_ADMIN "$ORACLE_HOME/network/admin"
SetEnv LD_LIBRARY_PATH
"/usr/local/mapguideopensource/webserverextensions/lib:/usr/local/mapguideopensource/webserverextensions/php/lib:/usr/local/mapguideopensource/lib:$ORACLE_HOME/lib"
file: $path_to_mapguide/server/bin/mgserver.sh (and/or)
file: $path_to_mapguide/server/bin/mgserverd.sh
export ORACLE_HOME=/u01/app/oracle/product/10.2.0/db_1
export ORACLE_SID=$orasid
export TNS_ADMIN=$ORACLE_HOME/network/admin
export
LD_LIBRARY_PATH=/usr/local/fdo-3.x.x/lib:$ORACLE_HOME/lib:"$LD_LIBRARY_PATH"
ORACLE_HOME, ORACLE_SID and TNS_ADMIN variables will need to be added.
As well, replace $orasid and fdo-3.x.x with appropriate values.
I think another option that might work, is to copy or symlink the oracle
client libraries into /usr/local/fdo-3.x.x/lib.
In either case, you'll need to restart MapGuide server for the changes
to take effect.
Hope this help or, at least, points you in the right direction
-- larry white
Sr. Systems Analyst
neomatix.ca
AmilkarQuintero wrote:
> Thanks A lot for your help, but the Autodesk Support in Linux is
> verrrryyyyyyyyyyyyyyyyyyyyyyyyyyyyyy disapointing for not saying an
> obscene word or phrase.  I created the case nearly a month ago and they
> "discovered" that my platform was not windows four days ago.
> If any of you see or listen to something like my error, I'll be pleased
> thank
> Bye
> Amilkar
More information about the fdo-users
