[fdo-users] Error: An exception occurred in
FDOcomponent.CLNT_8_UNABLE_TO_LOAD_LIBRARY
AmilkarQuintero
amilkar.quintero at gmail.com
Fri Mar 28 17:23:29 EDT 2008
Ok, its under /usr/lib/oracle/10.2.0.3/client64/lib
I included in the LD_LIBRARY_PATH and still the error is there, and the
command ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so still gives the same
answer
do I have to recompile the fdo?
On Fri, Mar 28, 2008 at 3:56 PM, Jack Lee <jack.lee at autodesk.com> wrote:
> Hi ,
> libclntsh.so.10.1 is not found. Can you verify if the file is under
> /usr/lib/oracle?
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *AmilkarQuintero
> *Sent:* Friday, March 28, 2008 4:53 PM
> *To:* FDO Users Mail List
> *Subject:* Re: [fdo-users] Error: An exception occurred in
> The answer to the command is
> [root at lucas /]# ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
> linux-gate.so.1 => (0xffffe000)
> libSchemaMgr_OVOR.so => /usr/local/fdo-3.2.2/lib/libSchemaMgr_OVOR.so
> (0xf76b2000)
> libSchemaMgr_OV-3.2.2.so => /usr/local/fdo-3.2.2/lib/libSchemaMgr_OV-
> 3.2.2.so (0xf767a000)
> libFDO-3.2.2.so => /usr/local/fdo-3.2.2/lib/libFDO-3.2.2.so (0xf7328000)
> libpthread.so.0 => /lib/tls/libpthread.so.0 (0xf72ed000)
> libclntsh.so.10.1 => not found
> libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xf7221000)
> libm.so.6 => /lib/tls/libm.so.6 (0xf71fe000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf71f4000)
> libc.so.6 => /lib/tls/libc.so.6 (0xf70c8000)
> libxalan-c.so => /usr/local/fdo-3.2.2/lib/libxalan-c.so (0xf6dc0000)
> libxalanMsg.so.17 => /usr/local/fdo-3.2.2/lib/libxalanMsg.so.17
> (0xf6db7000)
> libxerces-c.so.25 => /usr/local/fdo-3.2.2/lib/libxerces-c.so.25(0xf6a22000)
> libdl.so.2 => /lib/libdl.so.2 (0xf6a1e000)
> /lib/ld-linux.so.2 (0x56555000)
> [root at lucas /]#
> And yes, it is included in the LD_LIBRARY_PATH,
> */usr/lib/oracle*
> :/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/apache2/lib
> or am I missing the inner directory /usr/lib/oracle/10.2.0.3/client64/lib
> On Fri, Mar 28, 2008 at 3:48 PM, Jack Lee <jack.lee at autodesk.com> wrote:
> Hi,
> If you entered
> are all of the libraries found?
> It looks like oracle is installed under
> /usr/lib/oracle/10.2.0.3/client64/lib but the path is not included in
> LD_LIBRARY_PATH.
> *Sent:* Friday, March 28, 2008 3:30 PM
> Thanks A lot for your help, but the Autodesk Support in Linux is
> verrrryyyyyyyyyyyyyyyyyyyyyyyyyyyyyy disapointing for not saying an obscene
> word or phrase. I created the case nearly a month ago and they "discovered"
> that my platform was not windows four days ago.
> If any of you see or listen to something like my error, I'll be pleased
> thank
> Bye
> Amilkar
> On Fri, Mar 28, 2008 at 2:23 PM, Andy Morsell <amorsell at spatialgis.com>
> wrote:
> I'm with Jason at this point. Obtaining support directly from Autodesk
> for the non open-source Oracle provider would probably be your best
> bet.......
> Andy
> *Sent:* Friday, March 28, 2008 12:18 PM
> Andy
> The entry in the providers.xml file has the provider i am invoking
> <FeatureProvider>
> <Name>Autodesk.Oracle.3.2</Name>
> <DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
> <Description>Read/write access to feature data in an Oracle-based data
> store
> . Supports spatial indexing, long transactions, and persistent
> locking.</Descrip
> tion>
> <IsManaged>False</IsManaged>
> <Version>3.2.2.0</Version>
> <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
> <LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoRdbms.so</LibraryPath>
> </FeatureProvider>
> and the .so file is there too
> libFdoRdbms.so
> the LD_LIBRARY_PATH points to every lib path in the server
> /usr/lib/oracle:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/serv
> What could have been wrong with the installation
> Thanks
> Amilkar
> On Fri, Mar 28, 2008 at 11:49 AM, Andy Morsell <amorsell at spatialgis.com>
> wrote:
> This error generally means that the particular FDO provider that is being
> referenced by a layer definition is not installed on the server. Take a
> look in your /usr/local/fdo-3.3.0/lib directory at the providers.xmlfile. In that file, find the provider entry for the provider you are trying
> to use, look at the LibraryPath and see if the .so file that is referenced
> exists in that directory. If not, your initial FDO compilation did not
> create that provider and you will have to trouble-shoot your FDO configure /
> make process to see if you are missing any environment variables, library
> dependencies, etc.
> This page has information that might be helpful:
> http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html.
> Also, be sure to look in your FDO source folder (OpenSource_FDO) for the
> OpenSourceBuild__README.txt file which has important information regarding
> building FDO with specific provider support.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> *Sent:* Friday, March 28, 2008 8:34 AM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] Error: An exception occurred in FDO
> Hi, the following error is generated to the Error.Log file in my installation in Linux RH 4 ES. Has anyone solved this?
> *<2008-03-28T10:20:14> Administrator
> * Error: An exception occurred in FDO component.
> * CLNT_8_UNABLE_TO_LOAD_LIBRARY
> * StackTrace:
> * - MgFeatureServiceHandler.ProcessOperation line 83 file FeatureServiceHandler.cpp
> * - MgOpTestFeatureSourceConnection.Execute line 103 file OpTestFeatureSourceConnection.cpp
> * - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp An exception occurred in FDO component.
> *CLNT_8_UNABLE_TO_LOAD_LIBRARY
> Thanks in advance
> here I send some data about my installation
> - The mapserver is Autodesk Mapguide 2008 Enterprise for Linux
> - Linux lucas.siicar.com 2.6.9-67.0.7.ELsmp #1 SMP Wed Feb 27
> 04:47:23 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> - The Oracle Instant Client installation
> - /usr/lib/oracle/10.2.0.3/client64/lib
> [root at lucas lib]# ls
> libclntsh.so.10.1 libnnz10.so libocci.so.10.1 libociei.so
> libocijdbc10.so ojdbc14.jar
> In another server we have the Oracle Database with the Spatial Tables we
> are trying to access
> - The Oracle Server, Oracle RDBMS 10g Release 2
> - Linux juan.siicar.com 2.6.18-53.1.14.el5 #1 SMP Tue Feb 19
> 07:18:46 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> - Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
> - PL/SQL Release 10.2.0.1.0 - Production
> - CORE 10.2.0.1.0 Production
> - TNS for Linux: Version 10.2.0.1.0 - Production
> - NLSRTL Version 10.2.0.1.0 - Production
> Amilkar Quintero G.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080328/39fdcd90/attachment.html
More information about the fdo-users
