[fdo-users] Error: An exception occurred in
FDOcomponent.CLNT_8_UNABLE_TO_LOAD_LIBRARY
AmilkarQuintero
amilkar.quintero at gmail.com
Fri Mar 28 17:56:47 EDT 2008
I also ln -s /usr/lib/oracle/10.2.0.3/client64/lib/libclntsh.so.10.1
libclntsh.so.10.1 to run again the command
ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
[root at lucas lib]# ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
linux-gate.so.1 => (0xffffe000)
libSchemaMgr_OVOR.so => /usr/local/fdo-3.2.2/lib/libSchemaMgr_OVOR.so
(0xf76b2000)
libSchemaMgr_OV-3.2.2.so => /usr/local/fdo-3.2.2
/lib/libSchemaMgr_OV-3.2.2.so (0xf767a000)
libFDO-3.2.2.so => /usr/local/fdo-3.2.2/lib/libFDO-3.2.2.so(0xf7328000)
libpthread.so.0 => /lib/tls/libpthread.so.0 (0xf7316000)
*libclntsh.so.10.1 => not found*
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xf7221000)
libm.so.6 => /lib/tls/libm.so.6 (0xf71fe000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf71f4000)
libc.so.6 => /lib/tls/libc.so.6 (0xf70c8000)
libxalan-c.so => /usr/local/fdo-3.2.2/lib/libxalan-c.so (0xf6dbf000)
libxalanMsg.so.17 => /usr/local/fdo-3.2.2/lib/libxalanMsg.so.17
(0xf6db7000)
libxerces-c.so.25 =>
/usr/local/fdo-3.2.2/lib/libxerces-c.so.25(0xf6a22000)
libdl.so.2 => /lib/libdl.so.2 (0xf6a1e000)
/lib/ld-linux.so.2 (0x56555000)
On Fri, Mar 28, 2008 at 4:40 PM, AmilkarQuintero <amilkar.quintero at gmail.com>
wrote:
> echo $LD_LIBRARY_PATH
> /usr/lib/oracle:/usr/lib/oracle/10.2.0.3/client64/lib:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/apache2/lib
> On Fri, Mar 28, 2008 at 4:37 PM, Jack Lee <jack.lee at autodesk.com> wrote:
> > Hi,
> > No, you don't need to recompile FDO.
> > Is libclntsh.so.10.1 not found when you execute ldd?
> > What is LD_LIBRARY_PATH set to?
> > *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> > fdo-users-bounces at lists.osgeo.org] *On Behalf Of *AmilkarQuintero
> > *Sent:* Friday, March 28, 2008 5:23 PM
> > *To:* FDO Users Mail List
> > *Subject:* Re: [fdo-users] Error: An exception occurred in
> > Ok, its under /usr/lib/oracle/10.2.0.3/client64/lib
> > I included in the LD_LIBRARY_PATH and still the error is there, and the
> > command ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so still gives the same
> > answer
> > do I have to recompile the fdo?
> > On Fri, Mar 28, 2008 at 3:56 PM, Jack Lee <jack.lee at autodesk.com>
> > wrote:
> > Hi ,
> > libclntsh.so.10.1 is not found. Can you verify if the file is under
> > /usr/lib/oracle?
> > *Sent:* Friday, March 28, 2008 4:53 PM
> > The answer to the command is
> > [root at lucas /]# ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
> > (0xf76b2000)
> > libSchemaMgr_OV-3.2.2.so => /usr/local/fdo-3.2.2/lib/libSchemaMgr_OV-
> > libpthread.so.0 => /lib/tls/libpthread.so.0 (0xf72ed000)
> > libxalan-c.so => /usr/local/fdo-3.2.2/lib/libxalan-c.so (0xf6dc0000)
> > (0xf6db7000)
> > libxerces-c.so.25 => /usr/local/fdo-3.2.2/lib/libxerces-c.so.25(0xf6a22000)
> > [root at lucas /]#
> > And yes, it is included in the LD_LIBRARY_PATH,
> > */usr/lib/oracle*
> > or am I missing the inner directory
> > On Fri, Mar 28, 2008 at 3:48 PM, Jack Lee <jack.lee at autodesk.com> wrote:
> > Hi,
> > If you entered
> > are all of the libraries found?
> > It looks like oracle is installed under
> > /usr/lib/oracle/10.2.0.3/client64/lib but the path is not included in
> > LD_LIBRARY_PATH.
> > *Sent:* Friday, March 28, 2008 3:30 PM
> > Thanks A lot for your help, but the Autodesk Support in Linux is
> > verrrryyyyyyyyyyyyyyyyyyyyyyyyyyyyyy disapointing for not saying an obscene
> > word or phrase. I created the case nearly a month ago and they "discovered"
> > that my platform was not windows four days ago.
> > If any of you see or listen to something like my error, I'll be pleased
> > thank
> > Bye
> > Amilkar
> > On Fri, Mar 28, 2008 at 2:23 PM, Andy Morsell <amorsell at spatialgis.com>
> > wrote:
> > I'm with Jason at this point. Obtaining support directly from Autodesk
> > for the non open-source Oracle provider would probably be your best
> > bet.......
> > Andy
> > *Sent:* Friday, March 28, 2008 12:18 PM
> > Andy
> > The entry in the providers.xml file has the provider i am invoking
> > <FeatureProvider>
> > <Name>Autodesk.Oracle.3.2</Name>
> > <DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
> > <Description>Read/write access to feature data in an Oracle-based
> > data store
> > . Supports spatial indexing, long transactions, and persistent
> > locking.</Descrip
> > tion>
> > <IsManaged>False</IsManaged>
> > <Version>3.2.2.0</Version>
> > <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
> > <LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoRdbms.so</LibraryPath>
> > </FeatureProvider>
> > and the .so file is there too
> > libFdoRdbms.so
> > the LD_LIBRARY_PATH points to every lib path in the server
> > /usr/lib/oracle:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/serv
> > What could have been wrong with the installation
> > Thanks
> > Amilkar
> > On Fri, Mar 28, 2008 at 11:49 AM, Andy Morsell <amorsell at spatialgis.com>
> > wrote:
> > This error generally means that the particular FDO provider that is
> > being referenced by a layer definition is not installed on the server. Take
> > a look in your /usr/local/fdo-3.3.0/lib directory at the providers.xmlfile. In that file, find the provider entry for the provider you are trying
> > to use, look at the LibraryPath and see if the .so file that is referenced
> > exists in that directory. If not, your initial FDO compilation did not
> > create that provider and you will have to trouble-shoot your FDO configure /
> > make process to see if you are missing any environment variables, library
> > dependencies, etc.
> > This page has information that might be helpful:
> > http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html.
> > Also, be sure to look in your FDO source folder (OpenSource_FDO) for the
> > OpenSourceBuild__README.txt file which has important information regarding
> > building FDO with specific provider support.
> > Andy Morsell, P.E.
> > Spatial Integrators, Inc.
> > http://www.SpatialGIS.com
> > *Sent:* Friday, March 28, 2008 8:34 AM
> > *To:* fdo-users at lists.osgeo.org
> > *Subject:* [fdo-users] Error: An exception occurred in FDO
> > Hi, the following error is generated to the Error.Log file in my installation in Linux RH 4 ES. Has anyone solved this?
> > *<2008-03-28T10:20:14> Administrator
> > * Error: An exception occurred in FDO component.
> > * CLNT_8_UNABLE_TO_LOAD_LIBRARY
> > * StackTrace:
> > * - MgFeatureServiceHandler.ProcessOperation line 83 file FeatureServiceHandler.cpp
> > * - MgOpTestFeatureSourceConnection.Execute line 103 file OpTestFeatureSourceConnection.cpp
> > * - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp An exception occurred in FDO component.
> > *CLNT_8_UNABLE_TO_LOAD_LIBRARY
> > Thanks in advance
> > here I send some data about my installation
> > - The mapserver is Autodesk Mapguide 2008 Enterprise for Linux
> > - Linux lucas.siicar.com 2.6.9-67.0.7.ELsmp #1 SMP Wed Feb 27
> > 04:47:23 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> > - The Oracle Instant Client installation
> > - /usr/lib/oracle/10.2.0.3/client64/lib
> > [root at lucas lib]# ls
> > libclntsh.so.10.1 libnnz10.so libocci.so.10.1 libociei.so
> > libocijdbc10.so ojdbc14.jar
> > In another server we have the Oracle Database with the Spatial Tables we
> > are trying to access
> > - The Oracle Server, Oracle RDBMS 10g Release 2
> > - Linux juan.siicar.com 2.6.18-53.1.14.el5 #1 SMP Tue Feb 19
> > 07:18:46 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> > - Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
> > - PL/SQL Release 10.2.0.1.0 - Production
> > - CORE 10.2.0.1.0 Production
> > - TNS for Linux: Version 10.2.0.1.0 - Production
> > - NLSRTL Version 10.2.0.1.0 - Production
> > Amilkar Quintero G.
> > fdo-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080328/97ceb2a0/attachment-0001.html
More information about the fdo-users
