[fdo-users] Define a SQL as source instead of a tablename (MySQL)
Alexander Bruch abruch at e-vend.de
Thu May 8 11:59:53 EDT 2008
hi,
> Why can't you accomplish this with the use of views in the database?
because the source sql contains subquerys which cointains the user_id.
This user_id changes whenever another user login into the system.
Creating a view without the userid in the subsql will result in a big
performance problem.
I looked for this features in many GIS severs.
the only Server we currently found and have in production is the MapInfo
MapXtreme Server, which has a feature wchih is called Databiding layer
where you can define the SQL yourself..
> Also,
> you might try creating a secondary join to the primary datasource
> definition, but it will most likely perform more poorly than using a view.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Alexander Bruch
> Sent: Thursday, May 08, 2008 7:58 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Define a SQL as source instead of a tablename (MySQL)
> Hello,
> is it possible or will it be possible in near future to provide a SQL as
> datasource instead of using static tables?
> i.e. if i use mapguide studio to define a Layer, and i select a
> datasource,
> than i can only choose Tables or views, which are defined in MySQL.
> What i want is to enter a SQL, which should be used as Feature Source.
> It is not enough for me to define Queryfilters basedd on tables, because
> the
> datasource (SQL) is build up on complex joins which includes userids.
> Is this possible in FDO?
> Or is this just a missing feature in the Mapguide Server?
> thank you for answer
> Alexander Bruch
> http://www.nabble.com/Define-a-SQL-as-source-instead-of-a-tablename-%28MySQL
> %29-tp17127289p17127289.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
