[fdo-users] Re: Subversion problem? (Zac Spitzer)
Zac Spitzer
zac.spitzer at gmail.com
Fri May 23 00:17:50 EDT 2008
I think we could take a lot of load of the server if the code tarballs
included subversion tags.
On Fri, May 23, 2008 at 3:04 AM, Dan Stoica <dan.stoica at autodesk.com> wrote:
> Maybe your connection is slow and it times out. You may want to check the documentation for http-timeout...
> Cheers,
> Dan.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Joanne Cook
> Sent: Thursday, May 22, 2008 12:27 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Re: Subversion problem? (Zac Spitzer)
> Hmm,
> Well I have been trying on and off for two days now- including just now after you guys said it was OK, but I guess I can keep trying. Is there any other reason why I might get that kind of error?
> Thanks
> Jo
> Joanne Cook
> Information Systems Coordinator
> Oxford Archaeology (North)
> 01524 880212
> http://thehumanjourney.net
> Date: Fri, 23 May 2008 00:17:57 +1000
> From: "Zac Spitzer" <zac.spitzer at gmail.com>
> Subject: Re: [fdo-users] Subversion problem?
> To: "FDO Users Mail List" <fdo-users at lists.osgeo.org>
> Message-ID:
> <7a85053e0805220717r37abfce4o3ac3c3b20311f286 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> the svn server is the same as the trac server for osgeo i think....
> they both seem to be overloaded now and then
> On Fri, May 23, 2008 at 12:14 AM, Joanne Cook <j.cook at oxfordarch.co.uk> wrote:
>> Hi All,
>> I am trying to update my svn checkout of fdo (from http://svn.osgeo.org/fdo/trunk) but I get the following error message:
>> svn: REPORT request failed on '/fdo/!svn/vcc/default'
>> svn: REPORT of 'fdo/!svn/vcc/default': Could not read status line: connection was closed by server. (http://svn.osgeo.org)
>> This first happened yesterday, although it seemed to update one or two files the first time I tried it. It also happened when I tried to download a new checkout. To the best of my knowledge I haven't changed anything with my system, and I've used the same command to update my svn checkout in the past.
>> Is this an issue with the server or with my pc (ubuntu server 7.10, svn version 1.4.4)
>> Thanks
>> Jo
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fdo-users
