[fdo-users] .net Wrapper quirks
Traian Stanev
traian.stanev at autodesk.com
Sat Nov 1 14:07:58 EDT 2008
Hi Jackie,
The OGR provider has a weird implementation of the FDO refcounting. If the connection gets destroyed while you still hold on to certain objects that were owned by the connection, things go south. The refcounting in FDO has changed after I wrote this code, and I could probably reimplement the OGR connection using a safer approach as long as you are sure that it is only the OGR provider that fails -- does your code work for other providers?
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
> Sent: Saturday, November 01, 2008 1:45 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] .net Wrapper quirks
> I'll cite a more concrete example:
> http://code.google.com/p/fdotoolbox/source/browse/sandbox/FdoToolbox.Li
> b/Controls/GenericSpatialConnectCtl.cs#220
> This code builds the grid cells to allow you to enter the connection
> properties. Using the latest FDO trunk, if the provider is OGR, then
> once
> the method has completed, the application will die (with
> System.AccessViolation) if you switch (alt-tab) to another application
> and
> back in.
> With pdbs, the error message becomes:
> Unhandled exception at 0x0522f116 in FdoToolbox.exe: 0xC0000005: Access
> violation reading location 0xfeeefefa.
> With the point of failure being at:
> OSGeo::FDO::Connections::IConnectionPropertyDictionaryImp::ReleaseUnman
> agedObject()
> Now if I were to disable the using block on the connection that gets
> created
> (ie. Don't Dispose() the connection), I no longer get this access
> violation!
> Hence the Dispose() or no? question. I am confused.
> - Jackie
> Donald Cameron wrote:
> > I find my code throws exceptions on termination if I don't dispose of
> any
> > readers I have created during its execution.
> > Don
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
> > Sent: Friday, October 31, 2008 8:56 AM
> > Sorry to necro this discussion but it seems the dreaded
> > System.AccessViolationException has reared its ugly head again in my
> > testing
> > of FDO Toolbox with the PostGIS and OGR providers (I'm testing on the
> > trunk
> > build of FDO). I guess I need clarification on the following matters:
> > 1 - Dispose() or no? Should I just be letting the GC do its job.
> Could I
> > be
> > screwing up reference counts by Disposing objects myself, thus
> possibly
> > causing these errors?
> > 2 - The devguide states that method chaining is bad. Does this still
> apply
> > with the managed wrappers?
> > - Jackie
> > gregboone wrote:
> >> This is the primary cause of the defect as it results in an
> excessive
> >> number of SQLite resources being instantiated and used before enough
> >> resources are freed by the garbage collector. As a work-around,
> calling
> >> Close()/Dispose() should resolve the issue. However, we will also
> try and
> >> make a fix in the SDF provider so that these steps are not
> explicitly
> >> necessary.
> >> One last point, you still should explicitly assign the result of
> Execute
> >> to a Feature Reader so that the garbage collection can happen at an
> >> appropriate time.
> >> Greg
> >> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> >> Sent: Friday, April 04, 2008 2:38 AM
> >> Subject: Re: [fdo-users] .net Wrapper quirks
> >> I just looked at the unit test code for the ticket, and noticed I
> might
> >> have
> >> been doing something wrong.
> >> I forgot that IInsert::Execute() returns an IFeatureReader and so I
> >> haven't
> >> been closing and disposing them.
> >> One (of many?) possible cause(s)?
> >> - Jackie
> >> Jackie Ng wrote:
> >>> Hi All,
> >>> I've been writing .net code that copies data from one FDO
> connection to
> >>> another (Doing a series of IInsert::Execute() calls from an
> >>> IFeatureReader
> >>> ). In my adventures using the FDO .net wrapper, I have encountered
> the
> >>> following problems at random:
> >>> - System.AccessViolationExceptions ("Attempted to read or write
> >>> protected
> >>> memory. This is often an indication that other memory is corrupt")
> >>> thrown
> >>> at OSGeo.FDO.Runtime.Disposable.Finalize() (Target Site: void
> >>> ReleaseUnmanagedObject() )
> >>> - C++ pure virtual function call errors.
> >>> - Memory allocation failed errors.
> >>> Is there some quirks with the .net wrapper that I should be aware
> of? As
> >>> OSGeo.FDO.Runtime.Disposable implements IDisposable, I've been
> wrapping
> >>> nearly every FDO object used inside using() blocks. Could this be a
> >>> cause?
> >>> I am using .net wrappers for FDO 3.3.0
> >>> - Jackie
> >> View this message in context:
> >> http://www.nabble.com/.net-Wrapper-quirks-
> tp16318694s18162p16485877.html
> >> Sent from the fdo-users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
> > http://themapguyde.blogspot.com
> > http://www.linkedin.com/in/jackieng
> > http://www.nabble.com/.net-Wrapper-quirks-tp16318694p20265376.html
> > Sent from the FDO Users mailing list archive at Nabble.com.
> View this message in context: http://www.nabble.com/.net-Wrapper-
> quirks-tp16318694p20277762.html
More information about the fdo-users
