[fdo-users] .net Wrapper quirks
Traian Stanev
traian.stanev at autodesk.com
Sun Nov 2 10:17:18 EST 2008
Yes, then it's a problem in the provider and not the wrappers. I'll poke around to see what can be done.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
> Sent: Sunday, November 02, 2008 2:29 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] .net Wrapper quirks
> Hi Traian,
> This behaviour could only be observed on the OGR provider. Other
> providers
> work fine.
> - Jackie
> Traian Stanev wrote:
> > Hi Jackie,
> > The OGR provider has a weird implementation of the FDO refcounting.
> If the
> > connection gets destroyed while you still hold on to certain objects
> that
> > were owned by the connection, things go south. The refcounting in FDO
> has
> > changed after I wrote this code, and I could probably reimplement the
> OGR
> > connection using a safer approach as long as you are sure that it is
> only
> > the OGR provider that fails -- does your code work for other
> providers?
> > Traian
> >> Sent: Saturday, November 01, 2008 1:45 AM
> >> I'll cite a more concrete example:
> http://code.google.com/p/fdotoolbox/source/browse/sandbox/FdoToolbox.Li
> >> b/Controls/GenericSpatialConnectCtl.cs#220
> >> This code builds the grid cells to allow you to enter the connection
> >> properties. Using the latest FDO trunk, if the provider is OGR, then
> >> once
> >> the method has completed, the application will die (with
> >> System.AccessViolation) if you switch (alt-tab) to another
> application
> >> and
> >> back in.
> >> With pdbs, the error message becomes:
> >> Unhandled exception at 0x0522f116 in FdoToolbox.exe: 0xC0000005:
> Access
> >> violation reading location 0xfeeefefa.
> >> With the point of failure being at:
> OSGeo::FDO::Connections::IConnectionPropertyDictionaryImp::ReleaseUnman
> >> agedObject()
> >> Now if I were to disable the using block on the connection that gets
> >> created
> >> (ie. Don't Dispose() the connection), I no longer get this access
> >> violation!
> >> Hence the Dispose() or no? question. I am confused.
> >> - Jackie
> >> Donald Cameron wrote:
> >> > I find my code throws exceptions on termination if I don't dispose
> of
> >> any
> >> > readers I have created during its execution.
> >> > Don
> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C.
> Ng
> >> > Sent: Friday, October 31, 2008 8:56 AM
> >> > Sorry to necro this discussion but it seems the dreaded
> >> > System.AccessViolationException has reared its ugly head again in
> my
> >> > testing
> >> > of FDO Toolbox with the PostGIS and OGR providers (I'm testing on
> the
> >> > trunk
> >> > build of FDO). I guess I need clarification on the following
> matters:
> >> > 1 - Dispose() or no? Should I just be letting the GC do its job.
> >> Could I
> >> > be
> >> > screwing up reference counts by Disposing objects myself, thus
> >> possibly
> >> > causing these errors?
> >> > 2 - The devguide states that method chaining is bad. Does this
> still
> >> apply
> >> > with the managed wrappers?
> >> > - Jackie
> >> > gregboone wrote:
> >> >> This is the primary cause of the defect as it results in an
> >> excessive
> >> >> number of SQLite resources being instantiated and used before
> enough
> >> >> resources are freed by the garbage collector. As a work-around,
> >> calling
> >> >> Close()/Dispose() should resolve the issue. However, we will also
> >> try and
> >> >> make a fix in the SDF provider so that these steps are not
> >> explicitly
> >> >> necessary.
> >> >> One last point, you still should explicitly assign the result of
> >> Execute
> >> >> to a Feature Reader so that the garbage collection can happen at
> an
> >> >> appropriate time.
> >> >> Greg
> >> >> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> >> >> Sent: Friday, April 04, 2008 2:38 AM
> >> >> Subject: Re: [fdo-users] .net Wrapper quirks
> >> >> I just looked at the unit test code for the ticket, and noticed I
> >> might
> >> >> have
> >> >> been doing something wrong.
> >> >> I forgot that IInsert::Execute() returns an IFeatureReader and so
> I
> >> >> haven't
> >> >> been closing and disposing them.
> >> >> One (of many?) possible cause(s)?
> >> >> - Jackie
> >> >> Jackie Ng wrote:
> >> >>> Hi All,
> >> >>> I've been writing .net code that copies data from one FDO
> >> connection to
> >> >>> another (Doing a series of IInsert::Execute() calls from an
> >> >>> IFeatureReader
> >> >>> ). In my adventures using the FDO .net wrapper, I have
> encountered
> >> the
> >> >>> following problems at random:
> >> >>> - System.AccessViolationExceptions ("Attempted to read or write
> >> >>> protected
> >> >>> memory. This is often an indication that other memory is
> corrupt")
> >> >>> thrown
> >> >>> at OSGeo.FDO.Runtime.Disposable.Finalize() (Target Site: void
> >> >>> ReleaseUnmanagedObject() )
> >> >>> - C++ pure virtual function call errors.
> >> >>> - Memory allocation failed errors.
> >> >>> Is there some quirks with the .net wrapper that I should be
> aware
> >> of? As
> >> >>> OSGeo.FDO.Runtime.Disposable implements IDisposable, I've been
> >> wrapping
> >> >>> nearly every FDO object used inside using() blocks. Could this
> be a
> >> >>> cause?
> >> >>> I am using .net wrappers for FDO 3.3.0
> >> >>> - Jackie
> >> >> View this message in context:
> >> >> http://www.nabble.com/.net-Wrapper-quirks-
> >> tp16318694s18162p16485877.html
> >> >> Sent from the fdo-users mailing list archive at Nabble.com.
> >> >> _______________________________________________
> >> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
> >> > http://themapguyde.blogspot.com
> >> > http://www.linkedin.com/in/jackieng
> >> > http://www.nabble.com/.net-Wrapper-quirks-tp16318694p20265376.html
> >> > Sent from the FDO Users mailing list archive at Nabble.com.
> >> View this message in context: http://www.nabble.com/.net-Wrapper-
> >> quirks-tp16318694p20277762.html
> quirks-tp16318694p20287614.html
More information about the fdo-users
