[fdo-users] bulkcopy ArcSDE -> SQLite
Traian Stanev
traian.stanev at autodesk.com
Mon Nov 10 12:50:19 EST 2008
I don't think anybody has tried to use BulkCopy to output SQLite yet. In theory it should work... If it does not, you can always bulk copy to SDF and then use the SQLiteConverter which comes with the provider to convert the SDF to SQLite, and also create a Trac ticket against the SQLite provider, describing the problem.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of alucas
> Sent: Monday, November 10, 2008 12:47 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] bulkcopy ArcSDE -> SQLite
> Hello Traian,
> The used by the FDO provider.
> Thanks
> Traian Stanev wrote:
> > Which SQLite format are you talking about? The one used by the SQLite
> FDO
> > provider, or some generic SQL format?
> > Traian
> >> Sent: Monday, November 10, 2008 4:24 AM
> >> Subject: [fdo-users] bulkcopy ArcSDE -> SQLite
> >> Hello,
> >> It's possible to do this bulkcopy?
> >> Thanks in advance.
> >> View this message in context: http://www.nabble.com/bulkcopy-ArcSDE-
> >> %3E-SQLite-tp20416688p20416688.html
> >> Sent from the FDO Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> fdo-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
> View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--
> %3E-SQLite-tp20416688p20424669.html
More information about the fdo-users
