[fdo-users] ArcSDE connection string help
George McLean
gmclean at gorge.net
Tue Nov 25 13:23:44 EST 2008
Thanks Jack - This was very helpful. I am now able to connect to ArcSDE
using my .net code. My next hurdle appears to be creating feature
classes correctly. I have created a single feature class using ArcSDE.
This feature class is a line feature so I think it has geometry
properties. However, using the FDO API I am not able to see the feature
class. I started with a FeatureSchemaCollectrion object and drilled down
to the PropertyDefinition objects in the collection but there do not
appear to be any featureClass objects. I have used this same code with
Oracle and MySQL so am pretty sure it works.
Also, I can not see the feature class when I connect through Display
Manager.
Does anyone have any guidance on setting up feature classes in
ArcCatalog that might affect whether or not the FDO API can recognize
the feature class?
Thanks
George McLean
Jack Lee wrote:
> Hi George,
> You should use
> Server
> Instance
> Datastore
> Username
> Password
> You can get this information from IConnectionInfo::get_ConnectionProperties.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: Friday, November 14, 2008 7:31 PM
> To: FDO Users Mail List
> Subject: [fdo-users] ArcSDE connection string help
> I am connecting to ArcSDE 9.3 through the display manager without any
> problem. In the connection form I have 4 fields:
> Server name
> Instance name
> Data store
> version
> I am trying to build a connection strong in .NET to set the
> ConnectionString property of an object of type
> OSGeo.FDO.Connections.IConnection. Currently I am using a strong which
> works with MySQL and Oracle as follows:
> "service=Server name; username=MyUser; password=MyPass; datastore=Data
> store"
> I do not have the Instance Name or the version in this connection
> string. Do I need them? What is the correct sytntax for an ArcSDE
> connection strong in .NET?
> Thanks in advance!
> George McLean
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.9.3/1788 - Release Date: 11/14/2008 1:36 PM
More information about the fdo-users
