[fdo-users] SDE Error - Cant fine feature class
surrounded
Rob.Sosnowski at itd.idaho.gov
Wed Oct 1 10:59:20 EDT 2008
Hi Dan, Thanks
I get the following error when I try this:
'The connection is already open'
string providerName = getProviderName("arcsdeprovider.dll");
//OPEN CONNECTION
connection = getSDEConnection(providerName);
connection.ConnectionString = SDEName; //WHERE SDEName = "Cities". THIS
IS LINE OF ERROR
OSGeo.FDO.Commands.Feature.ISelect sel =
(OSGeo.FDO.Commands.Feature.ISelect)
connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select);
getSDEConnection returns a IConnection: code below
IConnectionManager connectionManager =
FeatureAccessManager.GetConnectionManager();
IConnection connection = connectionManager.CreateConnection(providerName);
IConnectionPropertyDictionary connectionPropertyDictionary;
connectionPropertyDictionary =
connection.ConnectionInfo.ConnectionProperties;
connectionPropertyDictionary.SetProperty("Server", "server");
connectionPropertyDictionary.SetProperty("Instance", "5151");
connectionPropertyDictionary.SetProperty("Username", "username");
connectionPropertyDictionary.SetProperty("Password", "password");
connectionPropertyDictionary.SetProperty("Datastore", "database");
OSGeo.FDO.Connections.ConnectionState connectState = connection.Open();
surrounded wrote:
> I establish a connection to SDE enterprise geodatabase:
> I use the following code to access the feature class:
> connection = getSDEConnection("OSGeo.ArcSDE.3.3");
> sel.SetFeatureClassName("Cities");
> reader = sel.Execute();
> On the sel.Execute I get the following error:
> Feature class 'Cities' not found in schema.
> Any ideas on why this is happening....Thanks
View this message in context: http://n2.nabble.com/SDE-Error---Cant-fine-feature-class-tp1131496p1131615.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
