[fdo-users] Spatial Filter Help Needed
Jackie Ng jumpinjackie at gmail.com
Thu Oct 2 12:53:00 EDT 2008
I see two things:
1) The filter is being created but not being applied to the select command.
2) I don't think you can apply filters on "aliased" properties. You should
be able to filter on the "Geometry" property and get the same result.
- Jackie
surrounded wrote:
> I'm trying to intersect a circle (created from input coordinates) with a
> shapefile.  I've created the circle geometry and am now trying to set up
> the filter.  In the code below, the statement
> while(reader.ReadNext())
> throws the follwing exception:
> "The property 'Shape' is not in the readers selected property set"
> SUGGESTIONS....THANKS
> OSGeo.FDO.Expression.GeometryValue pGVal = new GeometryValue(pByteCircle);
> OSGeo.FDO.Expression.ComputedIdentifier pPropName = new
> ComputedIdentifier("Shape", new Identifier("Geometry"));
> IdentifierCollection pIDColl = sel.PropertyNames;
> pIDColl.Add(pPropName);
> OSGeo.FDO.Filter.Filter pPtLineFilter = new
> OSGeo.FDO.Filter.SpatialCondition(pPropName,
> OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Intersect, pGVal); }
> OSGeo.FDO.Commands.Feature.IFeatureReader reader = sel.Execute();
> while (reader.ReadNext())
>      ......some code....
View this message in context: http://n2.nabble.com/Spatial-Filter-Help-Needed-tp1134329p1134362.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
