[fdo-users] SDE Error - Cant fine feature class
surrounded
Rob.Sosnowski at itd.idaho.gov
Fri Oct 17 08:16:59 EDT 2008
Hi Tony,
Using 9.2. I hear that FDO 3.4, due out near the end of this year (I
believe), will support ArcSDE 9.3. Rob
From: Tony [mailto:ml-user+64542-1977749538 at n2.nabble.com]
Sent: Thursday, October 16, 2008 5:14 PM
To: Rob Sosnowski
Subject: Re: [fdo-users] SDE Error - Cant fine feature class
what SDE version are you using
Tony
RESOLVED: I used:
//OSGeo.FDO.Commands.Schema.IDescribeSchema pDS =
(OSGeo.FDO.Commands.Schema.IDescribeSchema)connection.CreateCommand(OSGe
o.FDO.Commands.CommandType.CommandType_DescribeSchema);
//OSGeo.FDO.Schema.FeatureSchemaCollection pFSC = pDS.Execute();
to create a FeatureScheamCollection. From this I was able to get the
correct FeatureClass name. I used
the FeatureClass name in sel.SetFeatureClassName("xxxx")
WORKS FINE NOW.
surrounded wrote:
I establish a connection to SDE enterprise geodatabase:
I use the following code to access the feature class:
connection = getSDEConnection("OSGeo.ArcSDE.3.3");
OSGeo.FDO.Commands.Feature.ISelect sel =
(OSGeo.FDO.Commands.Feature.ISelect
connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Sele
ct);
sel.SetFeatureClassName("Cities");
reader = sel.Execute();
On the sel.Execute I get the following error:
Feature class 'Cities' not found in schema.
Any ideas on why this is happening....Thanks
View message @
http://n2.nabble.com/SDE-Error---Cant-fine-feature-class-tp1131496p13432
09.html
To unsubscribe from SDE Error - Cant fine feature class, click here
< (link removed)
raUBpdGQuaWRhaG8uZ292fDExMzE0OTZ8LTE5NTY2NDk3Mzc=> .
View this message in context: http://n2.nabble.com/SDE-Error---Cant-fine-feature-class-tp1131496p1344917.html
Sent from the FDO Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20081017/1cdb6b8c/attachment.html
More information about the fdo-users
