[fdo-users] ArcSDE 9.2
gmclean at gorge.net gmclean at gorge.net
Mon Oct 20 18:53:59 EDT 2008
I see the following:
dbo.SDE_states with one record.
dbo.SDE_VERSION with one record which indicates 9.3
instead of 9.2.
I am now assuming this is really a version 9.3 ArcSDE
installation. From what I see, 9.3 is not yet
supported. Is that true.
Thanks again for all the help.
George
------- Original Message -------
>From    : Thomas
Knoell[mailto:thomas.knoell at autodesk.com]
Sent    : 10/20/2008 3:39:48 PM
To      : fdo-users at lists.osgeo.org
Cc      :
Subject : RE: [fdo-users] ArcSDE 9.2
 Hi George,
The *_lineage tables are relevant when loading
version-related data. To retrieve the version names
in the dialog you should have access to the VERSION
and STATES tables. Do you see those tables?
Also, do you know how that data store was created?
Thanks
  Thomas
-----Original Message-----
mailto:fdo-users-bounces at lists.osgeo.org]  On Behalf
Of gmclean at gorge.net
Sent: Monday, October 20, 2008 6:17 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] ArcSDE 9.2
The only table I have from the list is
dbo.SDE_state_lineages. There is one record:
lineage_name = 0
lineage_id = 0
Thanks,
George
>From    : Jack Lee[ mailto:jack.lee at autodesk.com]
Sent    : 10/20/2008 2:29:50 PM
Cc      :
Does your datastore contains any of the following tables?
sde.state_lineages
sde.sde_state_lineages
sde.sde.state_lineages
sde.sde.sde_state_lineages
Of Romica Dascalescu
Sent: Monday, October 20, 2008 4:41 PM
To: FDO Users Mail List
Hi George,
There is a patch for Map2008 and ArcSDE provider
using 92 server.
The fix is not under Windows SDK its under "Patches"
- Ticket #294
 http://fdo.osgeo.org/content/fdo-323-downloads
 http://download.osgeo.org/fdo/3.2.3/patches/ticket294/fdoarcsde-3.2.3_win32_release_G071.tar.gz
Romy.
Of George McLean
Sent: Monday, October 20, 2008 3:49 PM
Subject: [fdo-users] ArcSDE 9.2
I am working through my first attempt to use the
ArcSDE provider.
I am connecting through Autocad Map 2008 to an ArcSDE
system running SQL
Server. In the data provider, I am able to log in and
see one data
store. I get an error message when I attempt to get
the version list.
The error states
-37 DMBS table not found
then
State info list could not be retrieved
I am not sure how to determine what table is missing.
Any suggestions?
This data store was set up by the GIS Administrator
for my client and
currently has no GIS data loaded. I am hoping I can
move data and table
defmitions from a MySQL data store to the ArcSDE
datastore through
Autocad's Bulc Copy. Will this work?
Thanks
George McLean
fdo-users mailing list
  http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
