[fdo-users] Arc SDE 9.3
Robert Fortin
robert.fortin at autodesk.com
Tue Oct 21 12:30:00 EDT 2008
George,
The thread you mention is not only 1.5 years old but also talks about Map 2007 which has been released in April 2006. It is using much older version of the ArcSDE FDO provider. Since then Map 2008 and Map 2009 have been released on updated FDO version and support for 9.2 has been added to ArcSDE Provider. Some of the problem discussed there are of course outdated mainly the multiple connection issue inside Map.
We already posted an unofficial version of the ArcSDE provider supporting 9.3. At the moment, it won't support dbo user (on SQL Server) or Windows authentication but it is the plan to support those features in the 3.4 release. Unofficial build can be downloaded from here http://download.osgeo.org/fdo/3.4.0/weekly/.
Some user on this thread have actually indicated that they used the existing provider using 9.3 client components against 9.3 server without any problem.
As Romy mentioned, you can download the latest patch for the provider depending on the version of FDO you want to use. Go to the FDO download page http://fdo.osgeo.org/content/downloads.
Hope it helps.
Robert
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of gmclean at gorge.net
Sent: Tuesday, October 21, 2008 11:56 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Arc SDE 9.3
Is there any estimate on when FDO will support ArcSDE
9.3?
The GIS administrator I am working with pointed me to
the thread below from an ESRI forum that says some
interesting things about FDO and SDE. I would be
interested in other FDO users experience with SDE
regarding stability, locking tables, database
connections etc. I realize the thread is over a year
old and there may have been some changes since these
comments were posted.
http://forums.esri.com/Thread.asp?c=2&f=59&t=216609&mc=9
Thanks
George McLean
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
