[fdo-users] Arc SDE 9.3
George McLean
gmclean at gorge.net
Wed Oct 22 20:35:30 EDT 2008
I am getting the error when retrieving the versions.
I am not sure if I am using the sde user. How can I verify that? When I
connect directly to the database through SQL Server Management Studio, I
see the user defined in the security tab. Does the user need to be
defined for sde separately?
Thanks
George
Jack Lee wrote:
> Hi,
> Fdo 3.4 dlls are not binary compatible with Map 2009 which uses Fdo 3.3.2.
> Are you using the dbo user or sde user?
> Did you get the error message when retrieving the versions?
> ________________________________________
> From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean [gmclean at gorge.net]
> Sent: Wednesday, October 22, 2008 6:05 PM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] Arc SDE 9.3
> Hi Robert,
> I am not sure how to try the 3.4 build but this is what I have done so far:
> I downloaded the fdosdk_3.4.0_win32_release_G032.tar and copied the
> dills and providers.xml file into the FDO\bin folder in my map 2009
> installation. When I do this and start Map 2009, mapstartwspace fails
> so I do not get the task pane. Should this approach work? I am guessing
> that I do not understand all the steps required to make this work.
> I tried connecting to ArcSDE using the version 3.3.2 providers but that
> failed with the error: DBMS table not found (-37).The GIS Administrator
> has been able to create a feature class using ArcCatalog with the same
> account I am using to access the data store so I don't think this is a
> permissions issue.
> Any suggestions? Thanks again for the help.
> George
> Robert Fortin wrote:
>> George,
>> As long as you don't use a dbo user, it should work. See my response to Jason too.
>> Just remembr that this is unofficial build of 3.4 so it's WORK-IN-PROGRESS still.
>> See the road map page for the release plan for FDO 3.4 http://fdo.osgeo.org/content/road-map
>> Robert
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of gmclean at gorge.net
>> Sent: Tuesday, October 21, 2008 2:35 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] Arc SDE 9.3
>> Thanks Robert, this does help. I was not trying to
>> stir things up too much with the thread I posted. I
>> just needed to know how relevant it was compared to
>> the present state of FDO and ArcSDE so I could take
>> that information back to the GIS administrator I am
>> working with.
>> If I understand you correctly, the weekly build will
>> support SQL Server with SQL Server Authentication. Is
>> that correct?
>> Thanks again.
>> George
>> ------- Original Message -------
>> >From : Robert
>> Fortin[mailto:robert.fortin at autodesk.com]
>> Sent : 10/21/2008 9:30:00 AM
>> To : fdo-users at lists.osgeo.org
>> Cc :
>> Subject : RE: [fdo-users] Arc SDE 9.3
>> George,
>> The thread you mention is not only 1.5 years old but
>> also talks about Map 2007 which has been released in
>> April 2006. It is using much older version of the
>> ArcSDE FDO provider. Since then Map 2008 and Map 2009
>> have been released on updated FDO version and support
>> for 9.2 has been added to ArcSDE Provider. Some of
>> the problem discussed there are of course outdated
>> mainly the multiple connection issue inside Map.
>> We already posted an unofficial version of the ArcSDE
>> provider supporting 9.3. At the moment, it won't
>> support dbo user (on SQL Server) or Windows
>> authentication but it is the plan to support those
>> features in the 3.4 release. Unofficial build can be
>> downloaded from here
>> http://download.osgeo.org/fdo/3.4.0/weekly/.
>> Some user on this thread have actually indicated that
>> they used the existing provider using 9.3 client
>> components against 9.3 server without any problem.
>> As Romy mentioned, you can download the latest patch
>> for the provider depending on the version of FDO you
>> want to use. Go to the FDO download page
>> http://fdo.osgeo.org/content/downloads.
>> Hope it helps.
>> Robert
>> Sent: Tuesday, October 21, 2008 11:56 AM
>> Subject: [fdo-users] Arc SDE 9.3
>> Is there any estimate on when FDO will support ArcSDE
>> 9.3?
>> The GIS administrator I am working with pointed me to
>> the thread below from an ESRI forum that says some
>> interesting things about FDO and SDE. I would be
>> interested in other FDO users experience with SDE
>> regarding stability, locking tables, database
>> connections etc. I realize the thread is over a year
>> old and there may have been some changes since these
>> comments were posted.
>> http://forums.esri.com/Thread.asp?c=2&f=59&t=216609&mc=9
>> Thanks
>> George McLean
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> No virus found in this incoming message.
>> Checked by AVG - http://www.avg.com
>> Version: 8.0.175 / Virus Database: 270.8.2/1737 - Release Date: 10/21/2008 9:10 AM
> Version: 8.0.175 / Virus Database: 270.8.2/1738 - Release Date: 10/21/2008 2:10 PM
More information about the fdo-users
