Re[fdo-users] turn geometries
Maksim Sestic
max at geoinova.com
Thu Sep 18 04:00:43 EDT 2008
Does SHP support MultiPoint geometries at all?
Regards,
Maksim Sestic
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Wednesday, September 17, 2008 19:34
To: FDO Users Mail List
Subject: RE: Re[fdo-users] turn geometries
> This should be something like "Point(-116.925 44.058, -116.xxx
44.xxx......)"
Sorry, I don't really understand this. A point with multiple positions?!
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
Sent: Wednesday, September 17, 2008 12:35 PM
To: fdo-users at lists.osgeo.org
Well, there is only one geometry returned. So for example, if I step
through the program (using C#.net) the point shapefile I referred to returns
the following from the CreateGeometryFromFgf:
"Point(-116.925 44.058)" for the text. This should be something like
"Point(-116.925 44.058, -116.xxx 44.xxx......)"
Gavin Cramer wrote:
> So... is the problem that ReadNext() only returns 'true' once, or that
> all geometries have the same value?
> Gavin
> From: fdo-users-bounces at lists.osgeo.org
> Sent: Wednesday, September 17, 2008 12:24 PM
> For instance, there are 44 counties within one shapefile - it only
> returns one. There are 100+ points in another shapefile, it only returns
one.
> NOTE: pcoords holds the geometry from GetGeometry - it is type byte[].
> I acutally pass this byte[] into another function to convert it into
> geometry with CreateGeometryFromFgf. That is why the code is not
> clear with the loop and the definition of pcoords.
> Thanks....
> Dan Stoica wrote:
>> I don't see any problem with that loop. Unless you get somehow an
>> exception and the loop beaks after the 1st retrieval. But you say you
>> get successfully one feature. So just to make sure: how many features
>> are in the SHP file?
>> Sent: Wednesday, September 17, 2008 11:45 AM
>> Subject: Re[fdo-users] turn geometries
>> Using shapefiles, trying to return all geometries for all features
>> within the shapefile. Using the logic below, the geometry is
>> returned for only one of the features within the shapefile. How do I
>> expand this logic to return
>> all geometries. Thanks....
>> OSGeo.FDO.Commands.Feature.ISelect sel =
(OSGeo.FDO.Commands.Feature.ISelect)connection.CreateCommand(OSGeo.FDO.Comma
nds.CommandType.CommandType_Select);
>> sel.SetFeatureClassName(sSplit[1]); //Where sSplit[1] is the name of
>> the shapefile
>> reader = sel.Execute();
>> while (reader.ReadNext())
>> pCoords = reader.GetGeometry("Geometry");
>> FgfGeometryFactory gFac = new FgfGeometryFactory();
>> IGeometry geo = gFac.CreateGeometryFromFgf(pCoords);
>> View this message in context:
>> http://n2.nabble.com/Return-geometries-tp1095647p1095647.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://n2.nabble.com/Return-geometries-tp1095647p1095772.html
http://n2.nabble.com/Return-geometries-tp1095647p1095800.html
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3447 (20080916) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
http://www.eset.com
More information about the fdo-users
