[fdo-users] Create an FdoFeatureClass?
Jackie Ng
jumpinjackie at gmail.com
Tue Apr 14 10:42:18 EDT 2009
Where does your feature schema originate from? Was it from a FdoIDescribeSchema command or did you create one?
- Jackie
I created the FdoIApplySchema command, called SetFeatureSchema on it with my new featureschema.
But does that schema also need to hold the current classes?
My steps were:
1. GetClasses on my featureSchema => FdoClassCollection
2. added an new class to this collection
3. Created the FdoIApplySchema command
4. called SetFeatureSchema (my new schema)
5. executed FdoIApplySchema
I think the problem lies with the FdoPhysicalSchemaMapping, I'm currently figuring out what I should add there. I think I may also need to call SetPhysicalMapping on the FdoIApplySchemaCommand.
Did you execute FdoIApplySchema passing in your modified FdoFeatureSchema ?
- Jackie
View this message in context: http://n2.nabble.com/Create-an-FdoFeatureClass--tp2611536p2633518.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
