[fdo-users] Create an FdoFeatureClass?
Jackie Ng
jumpinjackie at gmail.com
Tue Apr 14 12:43:28 EDT 2009
If the subsequent FdoIDescribeSchema returns a FdoFeatureSchema containing your new class, then everything worked.
If you want to be doubly sure, take a look at the PostGIS database with pgAdmin and see if a new table (representing your new feature class) is there.
- Jackie
I did not create a new Schema (did I?), but a new FeatureClass in the existing schema..
So I still have one FdoFeatureSchema at the end (tried the FdoIDescribeSchema afterwards), but it does hold one more class than it did before I tried (using GetClasses() on that schema). That one more class also has the correct signature (types, ...).
Jörg
If you execute another FdoIDescribeSchema afterwards does your new class appear?
- Jackie
View this message in context: http://n2.nabble.com/Create-an-FdoFeatureClass--tp2611536p2634089.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
