[fdo-users] OGR provider in 3.4.0
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Apr 20 03:31:46 EDT 2009
r4525 does fix the problem.
However, the 3.4.0 GA still has the problem.
I have created ticket #509 describing the issue, and providing a fresh
build that works.
Regards, Kenneth Skovhede, GEOGRAF A/S
Greg Boone skrev:
> If you still have the issue, send us the test and we can examine it to try and determine the issue.
> Greg
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
> Sent: Friday, April 17, 2009 11:43 AM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] OGR provider in 3.4.0
> If GA means General Avalibility, and is the one posted on the website as
> the official one,
> I have used that one with the same results.
> The actual text is from a run with my own
> build, which did not include the fix.
> I will try to apply the fix monday and observe the outcome.
> Thank you for the response.
> Greg Boone skrev:
>> This should be fixed in the 3.4.0 GA. Refer to:
>> http://trac.osgeo.org/fdo/ticket/498
>> Greg
>> Sent: Friday, April 17, 2009 7:34 AM
>> Subject: [fdo-users] OGR provider in 3.4.0
>> I am trying to use the OGR provider in MGE2010 and it fails with an
>> unclassified exception.
>> Digging a little with a custom build of the OGR provider, I can see that
>> it creates the OgrConnection object
>> through the CreateConnection API call.
>> Then without calling any methods on the object, it disposes the object
>> and returns the
>> The mapguide debug log shows this for "TestConnection":
>> Error: An unclassified exception occurred.
>>  StackTrace:
>>   - MgFeatureServiceHandler.ProcessOperation line 83 file
>> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>>   - MgOpTestFeatureSourceConnection.Execute line 100 file
>> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>> And this for a preview:
>>  StackTrace:
>>   - MgOpGetClasses.Execute line 105 file
>> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpGetClasses.cpp
>>   - MgServerDescribeSchema.GetClasses line 1527 file
>> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
>> Since the DescribeSchema call fails without ever calling DescribeSchema
>> on the provider, I thought that the OGRProvider may be missing some
>> required methods.
>> I suspect that Rfc23 might be the cause:
>> http://trac.osgeo.org/fdo/wiki/FDORfc23
>> This may be a MapGuide error, but I was hoping that someone from the FDO
>> team had tested the OGR provider with an application that uses
>> the new schema functions, or could give a hint towards the problem.
>> Thanks in advance.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090420/83228cdf/attachment.html
More information about the fdo-users mailing list
